Hey everyone, well today i finally picked up the car after getting a full tune on the Microtech. I've been running around running the new turbo on the stock computer for a few months now but finally its all done and i'm very very impressed with it!! Hands down to Peter at TMS in townsville for all his help with my car and doing an awesome job on it to get it perfect.
Mods
Full 3" Blitz Exhaust with Magic Cat
HKS GTRS Turbo
Microtech LT12S
Plazmaman Plenum
Greddy Intercooler
Nismo 555cc injectors
Tomei Fuel Pump
Splitfire Coilpacks
Exedy Cushioned Button Clutch
Still standard
Throttle Body
No Cold Air Intake or Heat Shielding
Camshafts
All Internals
Its low boost setting was set to the HKS actuator's base setting which was 1 bar and high boost was set at a bit under 18psi (tried running 20psi and started making more power however spark was being blown up at top end, need to run lower gap for 20psi). It has been raining up here in Townsville a lot lately and the humidity is huge, so this really didnt help with the tune (comparing to somewhere cold down south), however it still made good power for how hot it is.
The dyno graph is attatched above but its just the way the car drives that best describes it. Positive boost pressure is being made at about 1600-1700rpm and the turbo is very responsive, perfect for my type of driving and being a daily driven street car. With the microtech running map sensors it doesnt feal any different then it did running a stock computer and airflow metre. Acceleration is smooth, driving around is perfect under all conditions and idle is also perfect. Have read a lot about microtechs being a bit rough to tune and cant get perfect drivability like you can out of a Power FC but i honestly can't see it, i strongly believe it all comes down to the tuner and Pete did a great job. :cheers:
Now, me and Peter both agree that with some Tomei Poncams, lower gapped plugs so we can run 20psi and using a slightly bigger throttle body (maybe 15mm bigger, not too sure, havn't really looked into them other then the Hypertune ones), and a bit of heat shielding or a CAI, we can push around 285-295 out of my car. However at the moment i am more then impressed with it in its current form and wont be doing this for a while, but it still leaves me a little headroom if i want more.
So again just wanted to say thanks to Peter and everyone that helped with the car (Bobby, Pedro, Adam etc) to get it finally done and running. :)
Edited by PM-R33
https://www.sau.com.au/forums/topic/206618-hks-gtrs-finally-tuned/
  • Replies 62
Don't think the GT-RS will get you 295rwkw, but good luck with the future mods ;)
Agreed. The turbo is just too small.
I had a GTRS, till recently.
Mods:
Tomei Poncams
Extensive Head porting
Full 3" Apexi Exhaust
Wold3D V4
SARD 550cc inj
Bosch 044 fuel pump
Xtreme 9-puck Clutch
FMIC
Cold Air Intake with Heat Shielding
Splitfire Coilpacks
Standard:
Plenum & Throttle Body (match ported to head)
Manifold (match ported to head and hi-flowed)
All Internals
GREAT PACKAGE AND THOROUGHLY ENJOYED IT!!!; Till i cracked a ring-land on piston #3, at a track meet. :)
good result, perfect street turbo.
I used to run a mircotech and i loved it. Cheap to purchase, good tuning pints and map sensor, and like you said it all comes down to the tuner. You get someone that actually knows their stuff and the mircotech will never do you wrong.
nice one ,will see what happens when you put cams ,my money is on more torque not that much power ,what was your torque my last dyno was 844nm
He forgot to print out the torque figure graph so ill stop by later on this week and have a look. I wanna know aswell because it pulls extremely well so i think torque will be fairly decent.
Nice. I've got a GTRS going in very soon Hoping for about the same power.
You'll love it man, i gave it quite a lot last night :) and for the first time ever i was actually a bit scared winding it all the way to 7000rpm.
Ouch!! Thats a bit of damage there. Nice figure of 268 though, what boost was that on?
Exactly right, the tuner is everything and i have no complaints with the microtech what so ever.
Hey mate,
Good to see u have gotten such a good result!
Huge difference over running it untuned?
-Dragonforce
Huge man. Untuned it just ran like a dog, now its a completely different car to drive and power is just instantly available and over 4000rpm you just get planted in your seat. Ill take it to the drags once i get some better rubber for the rear. Took a few people for a bit of a drive and we all agree it should easily be a high/mid 12 in her.
Edited by PM-R33
should nearly do a low 12 with that power
Ill just be happy with mid 12s, up here its really only in the best winter nights when you can run good times, humidity and heat kills it.
how is the cold start with the microtech
Third go, every go.
Cold start is fine, it hunts around for a couple of seconds from 1000rpm to 600rpm until it settles. He tuned the idle for a few hours alone to get it right but he couldnt get it perfect. Probably due to the idle control valve being on an aftermarket plenum. But yeah not sure what the hell uz mean about third go, every go :/
Edited by PM-R33
nice result! what are ur afr's?? id assume ur running a rich tune?
When its ramping up onto boost its running about 10.9:1 and then once on boost sits on about 12.2:1 (looking at the dyno graph here, bit hard to tell exact numbers)
We chucked a good amount of fuel into it when it comes onto boost just to accomadate for a very hot day in traffic and coming onto boost so it doesnt ping.
Fuel economy is really good, just from driving around yesterday and today ive noticed very good economy compared to the good old days running the turbo on the stock ECU lol.
Nice result! cant wait to get mine tuned :/, only 25days away lol
What fuel? and are you still using the stock dump and front pipes or after market?
Edited by nizmo_freek
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
