:laugh: oh good lol
just a question, im thinking of changing the rear housing to a internal gated, with a actuator, and ive been quoted $1000 just to change the rear lol, i was like wtf.. might as well go highmount and its gonna cost me the same thing.
what you reocken?
:laugh: oh good lol
what you reocken?
Well if you go highmount you will need a new manifold(a good one is 1k+) a wastegate($500) new lines and a new dump pipe.
You will need a new dump pipe anyway internal or external. Going external will cost you more but will be a benefit if you plan to go bigger in the future.
Ill get some prices on an internal housing for you.
do wet the wrap as you wrap it.
do not smear silicone on it.
do paint over it with high temp paint if you wish but since you have the black stuff don't bother.
do wear gloves and mask/googles
do not scratch your balls, or pick your bum or rub your eyes or you will end up in a nasty, itchy hell.
Make sure you wash your hands before you eat very thoroughly! Been there, done that, itchy as hell mouth for days... hard to scratch in there as well :blink:
Same as yours mate :P But im already thinking about going to a GT3082. See how we go with this one first.
I vote, very very very hard - that you DO NOT go GT3082R. Max out the GT3076R first, you may be surprised at what they can do. If its not enough, don't mess about with the GT3082R - go to the GT3582R :banana:
I wet wraped mine gets a bit messy with water all over your hand while you try to wrap the man.
Can say ive been there with fiberglass was ripping the interior out of my GT pulling the roof lining off with no carpet in it and the bits of fiberglass on the floor pan and an itcy arse for days lol
Would like to see if he did scratch his nut would be a funny site to see lol
Yes its on the stand in my garage :) The blue is really going to look good against the white engine bay.
I have installed the ARP manifold bolts and trial fitted the manifold and turbo. Now im off to bed, i have alot of running around to do tomorow :D
Very few of them are, including the ones with "made in the usa" on the box. :D
My Pauter rods were made in the California factory ~5 years ago. Price was not much more than Asian manufactured options.
To my knowledge they still make every order to customers' specs at the same factory including titanium alloy if you can afford them (~US$1,400 per rod last time I checked).
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
