Spotted a blue R34 GTR with rego plates "V34GTR" cutting the wellington rd traffic by taking the service lane on the side and merging at the very end.
Dont cut through the traffic, wait in line like the rest of us, you flamin mongrel :D
with white wheels and fairly low?
I think i remember it as i thought... fark a SR20 in that would go nice
:P
yeah thats the one..i was just about to wave but some pedestrians walked out on to the road so had to keep both hands on the wheel..
its barely lowered but does have 15s which maybe makes it look lower than it is.
for now i am keeping it stock until i get the paint done, then maybe one of my Z18s or an SR20 might make it into the engine bay :D
Saw a few skylines today...
White R33 4 door with what loked like a small kit, down parmellia drive at about 4ish
Then saw a black R33 GTS-T down melton hwy a bit after had plates JSTNCE or something a rather
Spotted a yellow R32 at watergardens pub/hotel, think the owner might work there
Saved the best for last i saw a r33 gts-t with a GT-R badge at brimbank shops at around 5pm, must be rare lol
Spotted a really nice black R33 in the safeway carpark in Mentone at about 8:15 last night.
If the owner is a member here - I was the guy in the black MR2 that drove past you as you got out of your car :)
Around 2:45 at the intersection of Westall Rd and Heatherton Rd... ...A white 33 with a thick blue line down the middle... ...Gave him a wave... ...None in return...
Also same intersection while I was still waiting to turn right another white 33 tried to talk to me... ...couldn't understand him or hear him... ...Traffic was too loud...
R34PER in elsty tonight... sweet lookin GTT. it's one of the very few that i always see as clean as my car :D
I always feel the need to look after the object which consumes the majority of my wages hehehe
spotted Joeyjoejoejuniorshabadoo aswell.... was kind enough to take me for a spin WoW!! Boooost :(
thanks again mate, definitely helped to convince me to upgrade. ur car is an animal
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
