Fink your such a skyline hater :)
u got chopped many times, I seen it. And the rotors destroyed you guys too.As did that silver Soarer. That evo is pretty stock with a straight thru pipe.
I said before my car is broken kent lol. Got new spark plugs, needa chuck em in... then if its not that its coil packs...
That one rx3 was f**king insane. Had a flamethrower kit on it too.
Yeah that RX3 was insane. Almost as quick as the evo I reckon.
I might come again next week Kris :) Might take my car for a lap this time, just for shits and giggles. Will get absolutely destroyed :)
you feeling alright? Almost as quick? The RX wouldve ripped the EVO to shreds. Just cos he was doing limiter lauches doesnt mean its that quick, on a decent long run bye bye EVO
eh...I wouldnt do princes every week...if you do it will get to a point where the cops will block off the roads and do everyone hard...the purple ute was probably gathering info for a big bust
You guys are crazy!! Every time i go to princes hwy i get defected. And i dont drag or speet at all when im out there. How do you guys not get done going there every week just doing laps? Or do u figure you have imunity cos ur already defected lol?
yeah it was really odd.
40+ cars driving together up/down princes hwy. I bet there will be a massive crack-down next friday. Surprised how something like that can go ahead.
Saw a white 33 with P's driving like an absolute hoon on the nepean hwy near mornington around 5.30.
Plates were SLT*** something like that.
No wonder Skyline drivers have a bad name when there is idiots like that.
spotted Dez at Apollo Bay looking for a park, the Rays rims looks pretty sweet.
home to had a good drive home (if u were comming home)
Spotted you heading home once we were eating lunch, just caught the rear end of your car lol
Had a shocking run home through the otways, slow car after slow car...
did u see I lost a silencer out of one of my cannons...dunno how that happened. Id beed down a warnambool overnight so had 2x the GOR and was over it by then and just cruised alone from A.Bay awsome day though.
+ 1 I watched the RX3 rip the evo to shreds lol.
Seen a Pack of SAU stickered clowns on Princess highway tonite heading towards narre.
keep seeing the gayest 33 in the entire world on heatherton road... bright orange, f*kin ugly kit with gaybo stickers all over it, monster tacho, super uglor rims and god knows what else.
it actually makes me dry heave everytime i see it... actually just picturing it now... it... umm... oh dear
hasnt got snap on stickers all over it has it?...
    • My guesstimate, with no real numbers to back it up, is it won't effect it greatly at all.its not a huge change in position, and I can't see the air flow changing from in turbulence that much based on distance, and what's in front of it. Johnny and Brad may have some more numbers to share from experience though.
    • Which solenoid? Why was it changed? Again, why was this done? ...well, these wear..but ultimately, why was it changed? Did you reset the idle voltage level after fitment? I'm just a tad confused ~ the flash code doesn't allude to these items being faulty, so in my mind the only reason to change these things, would be some drive-ability issue....and if that's the case, what was the problem? Those questions aside, check if the dropping resistor is OK ...should be 11~14 ohms (TCU doesn't throw a flash code for this) ~ also, these TCU designs have full time power (to keep fault code RAM alive), and I think that'll throw a logic code (as opposed to the 10 hardware codes), if that power is missing (or the ram has gone bad in the TCU, which you can check..but that's another story here perhaps).
    • Question for people who "know stuff" I am looking at doing the new intake like the one in the picture (the pictured is designed for the OEM TB and intake plenum), this design has the filter behind the front bar, but, the filter sits where the OEM duct heads into the front bar, and the standard aperture when the OEM ducting is removed allows the filter to pulled back out of the front bar into the engine bay for servicing, a simple blanking plate is used to seal the aperture behind the filter This will require a 45° silicone hose from the TB, like the alloy pipe that is currently there, to another 45° silicone hose to get a straight run to the aperture in the front bar Question: how will it effect the tune if I move the MAF about 100-150mm forward, the red is around where my MAF is currently, and the green would be where it would end up Like this This is the hole the filter goes through  Ends up like this LOL..Cheers
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
