Spotted Emsta turning from narre - cranbourne onto the prinny around 8.30 this morning.
I was opposite you at the lights
w00t spotted!
yeah i think i remember you - u were behind another car (second row, middle lane?)
A while ago we saw a 350Z in an episode of Numb3rs and I made a post about it HERE... ...Well the 350Z has showed up in another show... ...Life was on 10 a few weeks ago and the 350Z made a small appearance...
Saw you too, have a soft spot for R31's as i used to own an Aussie GTS2, those Nismo LMGT's look sweet to.
Thanks mate, ah GTS2 I would love one of those, I'm thinking about putting a GTS2 spoiler on my silhouette, seen it done before it looks mad
also spotted another silver 4 door 34 with sau stickers turning right onto bayswater rd from canterbury rd around 5:30ish i think.
just how many nur specs did nissan make? every man and his dog has one nowadays
V-Spec II Nur had a production number of 750, M-Spec Nur only 250 units were made.
spotted a red r32 gtr going up burwood hwy in ftg not long ago had sau stickers
is that girl in your car's name Bec? lol i think i met her once, ages ago..
