Spotted Thread
paulr33
I work near the Ferntree Gully Nissan dealership..
Seen 5 R35 Gtr's being delivered there, 2 black ones and 3 white ones. they same in pairs on the back of trucks and one came with a 370z.
Goin to work today, saw a black 33, numberplates were either J3TBLK or BLKJ3T I cant remember
Candy purple/pink r33 coupe, chromies, (sounded like a non-turbo) with a cannon muffler last night around 6.30 near center road Hampton. Had personalised plates - seemed he wanted to race me *tisk* *tisk* - he gunned it at the lights.
My passengers and I laughed as you did not realise there was a portable speed camera about 100 meters away :(
This afternoon around 2PM spotted a stock red R34 coupe (not sure if it was a gt or gtt). I was behind you from Preston all the way to Thomastown - very clean car. I was not in my Skyline
At about midnight spotted a white R34 4 door heading away from the City on Princes Highway. There was a black R32 with an unpainted left front panel along side him for a couple of lights as well.
Was next to RB26T on Athol Rd last night at 10;20pm.
Also spotted a silver R33 S2 with front lip & SAU stickers on Cheltenham Rd turning right onto Springvale Rd tonight at 11:20pm
yellow 34 with full kit on springvale rd today.
then a maroon 33 gtst s1 next to us.
black 33 gtst at multilevel carpark at glenny.
spotted a 32 4door on burwood hwy at about 3:30am
spotted a black Stagea at dan murphys Rowville last night i gave a few beeps as someone was hanging out your window... pretty sure had SAU stickers
    • Yeah, so I think that is the point. If you presume a 25% lower reading on a chassis dyno than what the engine is making, then the most you would see from a 720HP engine is ~550wHP. "Lose" a little more because AWD dyno and the number will be lower. Call a hub dyno "wheel HP" and you should see higher numbers. But the horses would be a different size. And as Murray says above - an imposed 90% DC limit drops 550 down to 500 straight away. 80% takes you down to ~450.
    • Sounds reasonable to me.  Do you know what your injector duty cycle is? I guess everyone has their own personal limit as to how high they want to flirt with 100% duty cycle, but who knows what your tuners limit is. Maybe they like to cap it at 80%? Now your injector CC to HP conversion has a 20% hair cut on it, then through drivetrain losses, yeah 500rwhp seems ok to me.  If you plan to spend on your GTR, modern injectors and a modern ECU will go a long way!
    • @GTSBoythanks for replying. That's realistic and I always believed in the injector-hp rule of thumb. I am however making way less than that 😕 My guestimate/goal for the setup is a reliable 500rwhp, R33 gtr, seems realistic enough doesn't it?
    • 720cc injectors can only support about 720 engine HP. Maybe a little bit more. 600rwHP is, um, a plenty big chunk of that number. Probably running to the top of your fuel supply.
    • Hi gents, sincerely asking you guys the theoretical or actual power figures expected from the setup below: HKS Y pipes & 80mm cat back, Sard (denso) 720cc injectors, DW300 pump, R35 MAFs, Twin HKS 2530's (stock headers), Trust intercooler, stock BOV, stock intake plenum & TB's, N1 oil pump, MLS head gasket, forged pistons, poncam B's, Power FC, pump RON97, nismo coppermix twin plate, 18's on 265 rubber. So I've pretty much listed all that matters with regards to making and putting the power down. Asking as I may or may not be getting the full potential of my setup (bottom end was running 600rwhp on a different car). I have done numerous Dyno sessions with slightly different setups but more or less the same outcome which leads me to conclude (reluctantly) the setup is maxed out. Will share graphs but would like you to share your input first for better effect. Thanks in advance, guys!
