Spotted Emsta turning from narre - cranbourne onto the prinny around 8.30 this morning.
I was opposite you at the lights
w00t spotted!
yeah i think i remember you - u were behind another car (second row, middle lane?)
A while ago we saw a 350Z in an episode of Numb3rs and I made a post about it HERE... ...Well the 350Z has showed up in another show... ...Life was on 10 a few weeks ago and the 350Z made a small appearance...
Saw you too, have a soft spot for R31's as i used to own an Aussie GTS2, those Nismo LMGT's look sweet to.
Thanks mate, ah GTS2 I would love one of those, I'm thinking about putting a GTS2 spoiler on my silhouette, seen it done before it looks mad
also spotted another silver 4 door 34 with sau stickers turning right onto bayswater rd from canterbury rd around 5:30ish i think.
just how many nur specs did nissan make? every man and his dog has one nowadays
V-Spec II Nur had a production number of 750, M-Spec Nur only 250 units were made.
spotted a red r32 gtr going up burwood hwy in ftg not long ago had sau stickers
is that girl in your car's name Bec? lol i think i met her once, ages ago..
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
