Spotted white r33 on westgate bout 6:50 this mornin. Can't b 2 sure but might be same car on corner of dandy rd/chapel st lights - could feel your zorst in my car from three lanes away & thru the loud music. :D
This afternoon b/ween 4:30-5:30
skyline @ queens st, @ irving st footscray, & a 180 which turned left into hampden st braybrook.
Spotted Silver R33 GTR (I think) on Nepean Highway (Brighton) at about 8pm tonight, and I think he had SAU stickers too. We both cruised through a booze bus at about the same time, obviously a busy night for the cops to let two lines through like that! :rofl:
While getting a kabab with b3za and Basti tonight... ...we spotted a blue 33 turning from Clayton Rd onto Center Rd around 21:20... ...We had a short debate on whether the 33 came in blue and I think we decided that it was a respray in a 34 blue... ...I think I've seen this 33 a year or more ago at a meet... ...But I'm not sure...
spotted either a black or dark purple 33. leaving mulgrave maccas about 12:30 or something...had same led lights at the front as me.
then spotted a maroon 32 or 33 fly past in op[osite direction along wellington rd gunning it quite a bit about 5 mins later
and another silver 33 gtst at intersection of wellington rd/ stud rd
think it was friday. black r34 pulled over by unmarked ford outside Sandown Park trains station around 430.
and about 3weeks ago, (just clicked now) a white r33 pull out outside the tafe on Stuart street noble park by a marked car.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
