Silver 4-door R34 GT in Footscray around 4 pm. Seen it a few times around.
Saw quite a few lines at Highpoint tonight:
White R33 GTR with twin blue racing stripes down the middle parked near JB Hi-Fi
Silver R32 GTR
Black R33 GTS-T
saw a r31 skyline cruise pulled up on the M1 freeway heading to geelong.
also spotting a r33 around the same area ...
white r34 4door on p's and nismo sticker in Warrnambool outside the commenwealth bank ATM's.
white r33 with black wheels silver rims.
and a red Cefiro parked at Flying Horse (wrong spot but just on a roll)
Saw a crapload of skylines in the CBD last night around 10 pm.
Black R33 GTS-T near QV with For Sale stickers on rear 3/4 windows.
White R33 GTS few secs later.
Black R32 GTS25 with shameful HKS/etc stickers on the rear, parked on Lonsdale.
Silver R33 GTS-T with no spoiler.
Black R34 GT-T with ?bomex bodykit and removed spoiler on Lt Lonsdale.
None of these had personalised plates.
A few more I can't remember...
Yaar we were headin out to Lavers Hill for a pub meal and to enjoy some twisties on the way.
One of 'em shat a CAS.
ah nice i was gonna toot, but was dumbfounded by the nice looking r31's
i drove pass at the point where some dude in shorts and sunnies on was beating his women haha
RBPOWA
spotted you tailgating someone in the fast lane while the other two lanes were free lol
was in the white 180 with black bonnet heading geelong way
was that on sat'day arvo ? it was an Echo , my women hogging the fast lane,
think there was a maroon r33.
were you the one with the different tail lights ? type x or whatever their called
spotted silver r34 wit sau sticky and plates 1CNS-894 on citylink just after the chadstone exit around 9ishpm. I was on the fast lane when i passed thru, but did slow down after that to wave, too bad driver wasn't looking.=)
Saw quite a few skylines out at Mt Buller over the weekend - mainly R33s - 3 maroon, 2 silver (one of the silver ones was an r33 GTR with NSW plates).
Saw a silver/grey R32 and a white R34 wingless sedan drive past when I was in the shops at Mansfield.
saw a grey r33 last night think it was in Camperdown of Colac. . . WRC-***
camperdown of colac?
there a fair distance apart, also watch out for the arse hole cop in terang, he did me twice going up the hill towards warrnambool when i was going out there every night.
    • The HG high flow is excellent, and costs about the $$ you're talking about. But it, and probably every other highflow, uses a diffeent core than the original turo, and the original Hitatchi core is quite long. So, I think it is inevitable that there is likely no such thing as a highflow that just "bolts on" with no other effort required. And the same is likely true for HG's outright replacement "bolt on" turbos (the ATR things). And the same is likely true for anything similar from elsewhere. I have no idea if the cheap Chinese/Taiwanese complete turbos from eBay/Temu/etc are as bolt on as they claim. I mean, they claim the bolt onto the NAs as well as the turbos, and we know that can't be "bolt on". But it wouldn't matter because I'm not buying a $169 4 psi turbo for anything other than a paddock basher.
    • Bummer...yeah i "need" something to "ease" up the work and for my driving it would be enough.    Iam counting the tune "without" turbo. I do not mean "cheap" like something from Temu around 200 USD, "Cheap" is something around 1000 USD?
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
