was in my 4dr R34 mate. love your car its very unique! :( i drove past you as you were doing a u turn on princess looks like you had another black r34 following you, also saw you again tonight.
Spotted CR34M @ Wellington road BP and when leaving another yellow R34 cruising nxt to me up springvale road.
Also spotted few days ago mates car at the car wash he just got back.. made a jap cop car mock up (still in build) with plates to suit!
thats teh car i saw on craigieburn bypass
driving home on bell street saw a beautiful r34 GTR in blue very dark tints
about 5:30 tonight
also on doncaster road on monday about 12pm saw a silver r34 GTT with SAU stickers - turning where chemist warehouse is, pity i wasnt in my skyline :) or i would of waved lol
Hey Anthony, that was me in the GTR, I was behind you from St Georges Rd intersection and got caught in traffic. Couldn't get up beside you to wave until I had to turn off and realised you were right beside me! :)
First thing I was going to do when I got home was to hop on here and say I spotted an R33 with SAU stickers but you beat me to it :D
spotted last night at knox Black R32 with GTR front bar and old skylines australia sticker. also spotted beau making a hell of a lot of noise int he carpark lol
i first saw your car coming in i was like farkkk he got mad parker lights..then i come around corner n realise its youu =]
Poor rhys' R33 with a smashed ass and sideswiped side...poor thing, and Jennas 33 tonight at mine.
Also cruised with a white r33 and a grey 33 on dandy rd tongiht
after seeing purple 33 with plates on springvale rd and
grey 33 on kingston rd
all in the space of 30 mins...its whaling season....bad.
Spotted a White r34 gtt green p - plater on ryrie street in geelong around 5:30pm on sunday 9th of august.
And
An orange r33 on seperation street geelong around 1pm today.
Ooooh, Kris has competition?
Lol how is that bad?
Come to ballarat. We do not have many :mrt:
Come to ballarat if u want to see commodores, falcons and excels lol
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
