saw a nice blue r34 inbound on the monash at bout 2pm and a yellow r34 outbound at same time then another blue r34 on burwood hwy heading out of site near deakin uni and then a black r34 gt with white wheel on pound rd hallam. must be a day of 34's lol
anyone doing random run on princess now pls beware..there is an undercover cops hiding on princess hwayh, just after westall rd exit..next to the bp petrol station...give me a 'toot' if anyone sees me...i'm just few blocks away in my car stalking the cops=P
Edited by toshirokato
lol you tool haha. i need to head to kings down chetlenham road, and boundary rd. bit worried, cause car is going in next week to get patched up, would suck to get done for it
Silver 33, purple stickers all over. SAU stickers.
Collins Street, approx 10:30am.
im pretty sure thats htial or htail. cant remember how u spell it
Yarp... ...That'd be me...
Here's a tip... ...Costco is really freaking busy today... ...And there are heaps of rude parents with snot nosed kids... ...Not a fun place...
Is it as cheap as they say or just a gimmick?
ey this is my car but i thought since im in Vic i would post it up in this thread.
Whilst on here does anyone know what kind of front bumper mine is?? ive never seen it befor and really would like to know what kind it is.
Hope you all like it and can give me some infor on the type of bumper it is.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
