i keep seeing ftw. is that the same as wtf backwards?
wikipedia told me its "for the win" but im thinking WTF????.....confused :)
wiki is right, not everything on the intranets makes sense.
saw CR34M last night down princess hwy, heading towards dandy (the green 34 na)
and saw some blue r34 pulling out of chaple street in a hurry, no spoiler, think it had SAU stickers rear quater.
and saw a r33 with LED taillights parked on Chaple, near Chasers i think . .
silver GTR yesterday around 5:30 in rowville on bergins road.
soooooooooooooo PHAT
lol also spotted lukeB. was driving next to ya in a VE calais. didnt wanna scream out your name so i had my sau card and was pointing at it but you didnt look :) lol car sounds tough mate.
4 doors out in force today....lol
said Hi to "MANGUNE" 4 door r34 with mesh rims in Bayswater....keep your rims mate they look alright!
then a quick hello to "UNR34L" purple r34 4 door on cheltenham rd followed by and introduced to "B3ZA" but he was in a s13....are you sure its a sleeper?...damn quite a fancy looking sleeper you got there...lol
its good to see SAU people out there!
hahah.. the one time i take out the other car i run into a whole pack of 4dr R34's... FFFUUUU...!!! lol it was meant to be but i get carried away easily.. :)
Yesterday northbound on Elizabeth St, North Melbourne around lunchtime saw black R34 GT-T with sunnied azn guy driving with black plates [HAXORZ]
And at Highpoint around 2-3 pm yesterday:
White R34 GT-T with Mine's logos on the bodywork at the carwash there
Blue R33 GTS-T with CREATD stickers on the rear window, in the car park
Silver R34 coupe with what looked like a Veilside bodykit around Rosamond Rd.
All three had standard plates.
    • The powder coating came in at $250 EACH. The TRX rims got a coat of clearcoat on the outside only.
    • Bit wet, but YUMMY
    • Keeping in mind that I am currently getting flat 10 L/100km on my RB25DET, which means >>500km/tank. I would test this car for vacuum leaks, check codes and AFM signal with NissDataScan as D says, check plugs, do a compression check while they are out.
    • It is hard to be specific half way across the world...but it *seems* like it might have a minor issue. Is the idle stable and does it rev smoothly? I would not expect any pops out of what I am assuming is a standard ECU, standard tune, standard exhaust. You can use Nissan Data Scan to find out exactly what is happening when it runs, the cable/software is reasonably affordable if you are not planning on changing the ECU (which hopefully you are not with an NA skyline) BTW your mileage may not be that far off, these are heavy old tech cars, and being NA might mean you use a heavy foot to keep up with traffic....
    • Hey guys! Y'all are the masters so figured I'd check in on a few items here. - My engine sounds ever-so-slightly more raspy than the other NA RB25s I've listened to. It's barely noticeable but definitely a slightly different sound. - When I back off the throttle at high RPM, I will sometimes get a pop out of the exhaust, assuming this can be diagnosed as misfire. Some history on the car: - Had an exhaust leak in auction sheet but was claimed to be fixed by seller (bought from USA importer).  - Car's coil packs and sparks were replaced when it was sold to me, but unsure on what the gap is and whether the coil packs are correct.  - A prior mechanic had misdiagnosed a pilot or throwout bearing sound as LSPI/detonation. Had played with timing a bit, pops/raspy sound of engine just got worse. Got timing reset. - Had failed emissions a few times. First time went in as is, failed. Second time, replaced cat, still failed, running rich as hell. Third time replaced o2 sensor, passed. Car still smells gassy though. - Timing belt and valve cover gasket also replaced.  - Gas mileage is... low. about 350-400K per tank.  Any idea if I'm having any serious issues here or does this all sound like normal old NA RB stuff and I'm fine to drive it with the pops/slightly raspy engine? If it'll help, I can get drop a video of the sound of the engine.
