Swan St Richmond Today 1.20pm
White 33 s2 with no spoiler n dark as f**k tinted windows look nice
also was driving with a dark blue/grey 33 with front bar behind me
little flutter sounded nice.
spotted a white r33 go past me on reynolds templestowe @ bout 9:30am this morning - also comming home from work the other day down bell street - spotted a black maxima with skyline GT badges lulz
i went down renolds at around 10:20am turned from blackburn rd heading towards springvale?
Between springvale gtst was heading towards springvale rd and the gtr went towards blackburn and turned off.
I was in a black r32 gtst with a r32 gtr couple cars behind me on westal rd around 4:30pm.
I turned left towards blackburn and he turned towards springvale?
Did you spot us?
Did you spot us?
I was long gone by then.
Some silver R33 (I think) came out of nowhere and flew up behind me as I passed DT Panels on Sunday night.. was following real close to me until I put my blinker on, they put their blinker on too... then I turned in to a side street and they realised it was a no through road and turned in but did a u-turn and went off.
I don't see what the point of chasing me was lol..
Because you have a 34 GTR, they were hoping some of it would rub off onto the 33.
Yesterday saw no less than *FOUR* SAU-VIC Stickers:
1. Gunmetal grey R33 GTS-T westbound on North Rd, Brighton East around 10 am. Had some kind of bodykit... Veilside??? not sure. I suck at identifying R33 bodykits.
2. Yellow R32 GTS-T? somewhere in CBD in the morning, then again on King St around 6 pm.
3. White R33 GTS-T eastbound on Clarendon St, Southbank around 6:20 pm.
All had standard plates. Was in the daily so didn't bother waving or fumbling for my SAU card like a madman :(
Spotted a white r34 gtt coupe this morning on Bourke road, we both stared at each other as I was going the opposite direction. From my vague memory it had an ARC front mount intercooler.
spotted mint blue 32 gtr at glen near century city walk & shops...plates was gdzila or sumthing to do with it..fkn tuff az man ..always see it there..
black 32 gtst there aswel.
then @ the shopping centre carpark spotted a dull black coloured 33 gtst s2 had SAU sticker on frotn windshield.
    • From my youth: GTi-R clutch change is a massive pain. The gearboxes are fragile? But the car is super cool and I want one 😢
    • Remember this is 1988 tech.
    • Driveline vibration is resolved. I ended up loosening all my engine mount and trans mount bolts, giving it a good shake then retightening everything and it's gone... Let's just say I was surprised that fixed it.  I've been happily driving it around again but unfortunately put zero time into my direct port/constant pressure WMI setup. I'm on vacation next week, so I'll try and finalize it then.  On a different note, I spent all week fuel/ignition mapping 2x 216L V16 engines. Turbo's were burning glycol and we swapped them out for larger units. We also had planned emissions testing on site, so I figured I'd be there the same week to use their instrumentation and massage any emissions issues out if needed. This was a first for me. Fuel management is similar in certain ways to automotive (i.e air density as load variable) but very different in others. It's all PLC based and AFR's are controlled by air and not fuel. They use a control valve between the turbo and air manifold to control pressure which in turn controls AFR's. Due to this, target AFR tables supplied by the OEM are in pressures and not mass which really through me off. They use air pressure vs fuel pressure tables. I also relied on an O2 concentration sensor the emissions team had in the exhaust. Ignition timing was also all over the place and we were losing a fair bit of power. They're now happily sitting at 16-40BTDC depending on load. We were making about 1600kw at 900rpm at 90% load. Engines were running a lot smoother as well.
    • heh, aint no R32 ever meeting modern targa cage rules unless the driver is veeeery short OP, good luck with the sale, since its already in the land of freedom I'm sure you will find a good buyer.
    • meh, it was a good video, clear about the issue and how he dealt with it. A bit heavy on the RTV and very brave to put an RB in anything without rebuilding it first, but otherwise I thought it was good Dose, I'm not sure that having the pickup forward is a big issue; yes of course the oil could shift under brakes but the sump should never be empty enough for that to be a problem (unless you also have a higher volume oil pump, and that oil can't return from the head to the sump quickly enough)
