forgot to mention i saw Kriss's mate with the red r31 on cheltenham road and springvale crossing..too...forgot him name..what was it?
Think i saw you earlier tonight getting onto princes highway from that round-about next to Ernest Wanke Rd. Was that you?
Saw a white r33 coupe being driven hard by a curry dude in Reservoir this morning... on space saver (spare) tires.. yikes. brave/crazy or trying to save on fuel???
Also say JNRZAN near la-trobe uni - black R33 coupe.
Yeah i was think i was playing golf at bundoora that day lol were you in your 34?
His name is Niz
Sick..ill try to remember...lol..so bad with names...Well spotted NIZ...is he in this forum?
Nah wouldnt be me...i was driving my daily...a shitty red commodore..lol...i have noticed another 33 gtr silver in colour driving around the area..prob is him....
Also Spotted MrWindsurf this morning again...
I didnt see you this morning were u in the ninjadore?
Also sportted a white 34gtr on doncaster road last night at about 7:30 turning onto williamsons rd
HAHAHA!!! ;) ninjadore...yup i was in it...saw you just before the pound road exit...
Also around 2:30 saw white gtst (tranman?)...from berick road entrance to the freeway till belgrave hallam road...
Same time spotted a midnight purple 33 gtr heading the other direction towards bewrick....LOOKED TUFF!!! :D
Spotted boostn0199 today around lunch time or maybe a bit after cruisin up Camberwell Rd past the cop shop.
Also spotted white 4 door R33 parked 6 doors up the hill a bit from boostn0199 house the other night rego was RGTS33 or something close to that.
saw CR33M and CR34M cruising together, a midnight purple r33 GTR and a black r32 gtr with 33 gtr wheels.. all on princes lastnight
i was in a blue ba xr6.. its until i get my zillr on the road :D
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
    • Wrinkle black will be a thing for both
