Clean red SVD R31 with white wheels and personalised plates following me, this morning along Warrigul Rd.
Saw a white R34 coupe (not sure if it was a GTt or GTR from afar) along Dalton Rd Thomastown around 9am.
Spotted...
  1. white r32 gtr - dynon rd
  2. gray r35 gtr - also on dynon & followed it to droop st
  3. whole passels of skylines @ chasers
  4. white r33 - droop st/geelong rd
  5. burnt orange 350z - also on droop st
  6. forest green s14 - ballarat rd
  7. another forest green s14 - followed from mt derrimut rd into brimbank gardens
:down: was bored going home today so was playing spot the jap imports
Wine red R33 boosted it past me along St Georges rd.
I caught up at the red light - he kept looking forward....
Big NISMO sticker across the rear windscreen
I feel no love.
Why show off and not look at me? You obviously proved you can reach a red light faster than me.
on the other hand i cruised with a sexspec little fwd thing. so much kit chrome and candy green that i couldn't tell what it was, but it was turbo, and fast. took it very easy despite four or five commodores trying to race the both of us all the way down stud rd from knox. gave it a little hit to 80 at cheltenham rd from chandler rd lights, gave eachother a wave, and he turned off, i went home. guys in r33's are massive dicks in comparison
I feel no love.
See my diagram up top for an explanation!
I think I've had one R33 acknowledge me, ever...and that was the night I picked up my car :P
What pisses me off though, is that you know they know you're there...it must take some control to just keep looking forward like that and pretending you don't notice.
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
