saw Julz at blackburn maccas this evening... was inside punishing some food.
and another white 34 with SAU stickers near the freeway entrance on Doncaster road
saw ur car too bro. i just got out of bed haha, needed a cheesie boi to get me going again haha
does julz own a black 33?
nah man black and white r34 brah
hektik i just noticed ur sig. gold bro haha
Edited by GUN_METAL_GTR32
haha i thought so that it was you! I dont think any other red mr2 would come to a stop in the carpark! :laugh:
Was attending a work dinner
Should have said something/parked next to me instead of driving off to the other side of the carpark haha
Nice clean mr2!
Sorry, I was running away because my car was so embarrassingly dirty :banana: Will stop for a chat next time for sure!
saw "UNR34L" (i think thats what it was, purple 34 sedan with white rims?) parked next to a white 33 at Coles down sandringham way about half an hour ago. seen them there a few sundays just never noticed the licence plate
Friday night on Racecourse Rd, Flemington pulled up next to a very clean White R34 GTR V-spec with LED tail-lights.
Driver wound down his window and we had a quick chat. His girlfriend was like, who the f* is that? LOL
Feels good when you randomly meet another friendly enthusiast driving the same car.
UNR3AL. It's my boyfriend's brother's car :worship: used to be NA, turbo engine conversion.
Crap night last night :)
+1...wanted to do something but in the end called it a quite one too...if you remember i walked up to your car to say hi in the shell in oakleigh but you kept driving :)....
Also spotted a silver 33 gtst parked in the emergency lane on the freeway outbound and looked like it was there all night....anyone from here? hope its ok
Spotted MrWindsurf this morning too.. :(
saw white r34 gtr driving driving king st in doncaster just mear serpells rd near my house. number plate was ZELE. then think i saw it again later in the night on donny rd
Tangomatts car!
1 of the best R34 GTR's around!
    • yeah first and reverse is where you will find clutch release issues (whether hydraulic or mechanical) because the difference in revs required is the highest there; particularly changing down from 2nd to 1st when still moving. To be clearer though, it is possible that the clutch release bearing is the wrong height. This is less likely than a hydraulic issue but it is not unheard of when you are mixing and matching
    • Quite right, if you make it to that pension you deserve every cent
    • Hi all, Restoring r33 series 1 rb25det. All the heater hoses were on their way out, have replaced them and put it all back together. After testing I noticed a small leak from behind the head on the actual metal water line to the turbo when cars warm. I tried running a longer hose over it but it kept leaking...   I am about to take the (stock) manifold off again😔 to change the water line does any one have any lines they recommend? I was looking at Aeroflow Turbo Oil & Water Line Set but not sure what everyone else recommends. Car is completely stock but want to upgrade turbo eventually. it looks like ill have to disconnect a lot just to replace these lines so if there's anything else recommended to do please let me know. Thank you in advance!
    • From memory, on the R33 GTSt at least, while everyone says "It's not adjustable", I found when I changed clutches in mine, it just needed a small adjustment on the rod length. But be very wary here, as you could end up trying to push the pushrod in the master too far, or blowing out the slave.   Most likely though, if the master/slave isn't bypassing internally or leaking out, then the throw out is the wrong height compared to the fingers on the clutch, so when it moves to disengage the clutch, it isn't 100% disengaged. You can check part of this out too by jacking the car up, having the engine running, put your foot on the clutch and try to engage 1st gear. If it goes in pretty easy (Compared to the ground) and/or the wheels start turning a fair bit and it takes a bit too much brake pedal to bring them back to a stop, this is likely the issue.  I'm not sure if you can adjust the height of the forks etc in these though, it's been that long since I've touched any RB gearbox.
    • That's all good, I thought I was missing some interesting feature! Maybe @PranK can double check if that is something that is meant to be operating or not.
