^ wherr on blackburn rd is that?
yep after freeway just before ftg road, next to petrol station on corner. owner watches it like a hawk as soon as i pulled up next to it he came out to talk to me. nice guy and down to earth, not arrogant at all.
Spotted a silver 35gtr at the pines shopping center outside the learning center
It isn't there anymore.
Spotted MP 33R and Pearl white 34 with Tommykaria bumper on a street I drive everyday at the moment in Doncaster East near where I live. Nice collection.
spotted gd2ila on FTG rd round 4:30 on thursday arvo, and a black 32 gtst with drift teks each morning around 6:50 on commercial rd in FTG going onto the start of ftg rd
haha, was wondering if you were on sau.
Last week had training in the city so had to wake up early :(
Do you live around the area?
(they uras ns-01's btw :P)
should have given a beep or sms'd :P
yeah you had gone past before she couldve beeped and phone was in my car lol
saw you pull into the shell, but was heading for lunch and hadnt eaten all day so cbf stopping lol
Spotted a Bayside Blue R34 GTR with plates ZLA xxx around 5:15pm on Cooper st Epping.
Also spotted a SIlver R33 GTR with R34 GTR rims parked near Roxy Kebabs.
Loved them both <3
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
