Spotted what looked like a 1999 silver r34 gtr yesterday on gladstone road right where the car wash/speed camera is. Number plate was 99 gtr or something like that. Only saw the front of the car as we were on opposite sides, but it looked real nice.
that would of been me :cheers:
Spotted a nice white 33 with some big decals vynals down the side looked like a workshop name or something and the. 10 mins later got a toto and a wave from a white 33 gtr both in mt Evelyn about 6 6:30 ish
R Power?
Brad - That's Evans car, owns Rpower Motorsport. He built my car, has a few GTRs being built there atm. Top work, great bloke.
https://www.facebook.com/RpowerMotorsports
Edited by ShyBoi
Spotted white r34 gtt at lynbrook Kfc had sau stickers on both sides. I was in the black 33 gtst. Was gonna come say hi then u left lol
I think that was me. I was teaching someone how to drive manual in the industrial area behind the kfc.
spotted a white 4dr 34 gt-t in carrum downs yesterday, had the plates [GTT4DR] or something like that, parked on the side of a street. had a SAU sticker on the drivers side rear quarter window.
    • Lets say I wanted to buy this, specifically for this purpose. How do I actually perform the function. Can I still buy a Consult-1? Am I about to be burned by the fact my car is a 2000 model Series 2 R34 and thus will be some stupid other system? Do I just need this -> https://obd2australia.com.au/product/nissan-consult-14-pin-to-usb-ddl-diagnostic-interface-with-ftdi-ft232r-chip/ And with what software?
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
