Not sure what you're trying to ask, but i'll try to answer it
The following is just MY OPINION and may be incorrect or possibly damaging :spam:
This done in what i beieve is my order of performance modification
100% std car - 7psi
Full exhaust system , quality panel filter, bleed valve - 10psi
FMIC - 10psi
aftermarket ECU - 13psi
Upgraded turbo - 18psi
rebuilt engine using quality performance parts - 20psi (pump fuel) / 35psi (race fuel)
All depends on the tunning :D
Boost DOES NOT equal power. Making the engine "breathe" easier and having less flow restrictions produces power. :thanks:
In fact boost produces heat and too much heat results in less power :spam:
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3754271
Iv heard rumours that if u slap on a TYPE R sticker on the fenders, it gives you 10psi extra boost, just like that, even on non-turbo cars.
thats a vtec sticker you idiot! typeR ones are good for another 1k added to redline
I'm assuming the thread starter is fairly new to all of this so i'll cover the basics, some of which has already been mentioned.
You can just add boost. a bleed valve or ebc will do it. It's virtually useless without freeing up the exhaust first.
In terms of the basic mods, exhaust, intake, intercooler, boost controller, management, injectors & pump, afm, turbo in that order
There is a lot of information floating around, check the sticky dyno thread up the top to give an idea of what mods do what to power.
Edited by BHDave
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3754437
thanx for your answer r33cruiser and exspecially Al.
And for you paulr33 go and die. Im not wanting to blow up my engine. And for the rest of you grow up. Why give stuipd answers when there not needed for? I asked a valid question and i got a valid response why add spam to the board and try and make yourselves feel and sound mad? Get a life.
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3754850
Maybe if you worded the question a bit better it might make more sense, however looking at the dyno thread at the top of the screen, is a great way to learn what you need to make the power you are after.
PS pauls answer was the exact correct answer to the question you asked
Edited by Adriano
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3754895
ow fully sic mate, slap a sticker on the side, grab ya self like 50PSI :) . Everyone knows a sticker dosnt add anything. SO why say stuipd shit? This is what ruiens these forums stuipd responses.
Dude, no.
What ruins forums is people who post the same old question for the 5000th time. And then get offended when it's pointed out.
ffs search you humourless nub.
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3755414
High, Just wondering what sort of mods you can do to a car, any turbo car really weather it be 180sx or a r32gtst. Just wondering what mods let you ahieve a certain amount of more boost? E.G 'blah' adds 1-2 PSI.
just get a boost controller and run whatever boost you like
thanx for your answer r33cruiser and exspecially Al... And for you paulr33 go and die.
Ouch...
:laugh: Paul did technically answere the Q it seemed like u were asking ;)
Edited by GeeTR
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3757121
dude, chill out, paulr33 is right you know, thats what boost controllers are for. you can turnit down to 2psi if you want to. If you run 10-12psi on a normal engine/turbo, its not going to blow up.
https://www.sau.com.au/forums/topic/212483-high-psi/#findComment-3757147
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
    • I would say no, why, because my daughter, who also lives in Goulburn, hasn't recommended us going there Pity, as we miss all the German joints around in Sydney, actually, the restaurants are the only thing I really miss about Sydney, and a special mention to Ishibanboshi at Bondi Junction, their Kara-age Don is heart cloggingly deliciousness (always added a special boiled egg...or 2) 😋
    • Does that German restaurant still exist in the old place out the NW end of Goulburn? When I say "out the NW end of"...I am really being vague. It was 1997 when I was last there, and the only point of reference I can recall is that it was on the opposite side of the main drag from the big merino. And when I say "opposite side of the main drag", I don't mean "on the main drag". It was either a couple of streets back from there, or might have even been out in the sticks a bit further. Was an old farm building or mill or somesuch. And when I say "the big merino" I might actually be thinking of a completely different part of town, because I just looked on maps and the big bugger is not where I remembered him to be! The food was good, consisting largely of various German mystery-meat sausage/loaf things and kartofflen.
    • So while the second sentence is completely correct and the whole point of the conversation, the first sentence bears consideration. If this bloke is just hoping to throw big turbos on and drive it around, because there are no helpful facilities at all in his tropical paradise** then he likely has zero chance of even knowing what the TP is on the last column in the stock maps, let alone know whether the ECU is operating anywhere near it or past it. So the point is very very moot. And, per what I said before, at stock boost on those turbos, you may well be off the end of the map. **I'm just back from Vanuatu, so I know exactly what small Pacific nations can be like wrt paradise without requisite facilities. But it's not even that simple. I put a high flow on my car and had to drive it around without a proper tune because of the lack of opportunity*** to put the bigger AFM and injectors into it to allow it to be tuned. I had to turn the boost down to less than I had before, and back off the boost controller's ramp, because it was exploring parts of the map that it didn't drive in before, and really couldn't access for tuning on the dyno either, and so was pinging. It was still well within the last column, because when I first**** set up the Nistune on the Neo I rescaled all axes of the maps to give some more space to explore. ***Family dyno was broken ****This was 13 years ago, and the TIM thing wasn't a thing then and so TP would definitely grow when pushing past the stock tune's limits.
