  • Replies 895
the timber species Tasmanian Oak is actually mixed tassie and vic trees like vic ash mountain ash messmate etc but its labeled OAK cos European people believe that ash is a sub species.
Enough "oh but its a vipec not a link its a link not a vipec." more about tuning results please. i couldnt give a rats arse who makes it. just as long as its good and has the proof to back it up
i think 12 pages back we all agree it is good, ive used both Vipec and Link G4's with great success, but as said a page back if you have a PFC and expect to get more power just by changing over you are wasting your money.... check over the options and if you need extra functionality and are reaching the limits of your current ecu then i cant reccomend the LINK or Vipec enough as they are great to use and driveability is as good as a well tuned PFC remap etc, far better driveabilty than any microtech etc..
hey all
im about to put a r32 rb26 into my 33 gtst, i currently have a 33 gtst pfc, but from reading i presume i would need the r32 rb26 vipec to run this motor? is that correct, and then would also need a standard 32 gtr ecu to put the vipec board into??
hey all
any r 32 33 or 34 stock ecu case will fit the vipec board
the vi-pec board suits rb20/25/26
speak to alistair @ Autoworx or contact Lumpy (the distributor in WA) for any details
Edited by gazza750
i figured out why flat shift wasn't working for me earlier this evening, i must say its a good bit of fun now that it does work, though traction between gears is a bit of an issue.
how do you set it up? where were you going wrong?
Wire up one of the digital inputs to the clutch switch and set it up as a "GP Input".
Check that the settings are correct for the way you have wired the switch using the "Digital Inputs" tab at the bottom of the software. (this is the bit where mine was playing up the rising/falling setting was set incorrectly so it was activating as the clutch pedal was released rather than depressed which makes for an interesting drive)
Turn flat shifting on i have found that around 0.75 seconds for the cut period works well for me.
Then just setup what RPM you want it active above with what % of throttle you want it to activate over.
i found that my car with a fully functional stock BOV holds ~8psi (running 12psi) during the gear changes and the boost is pretty much instantaneous when the ignition cut finishes.
Edited by TiTAN
cheers man, will do that when purchase time gets closer
Just a wild question, its probably been asked before, but i couldnt be bothered reading through the 20+ pages.
Does anyone know if there are any decent tuners for the vipec here in Auckland, NZ??
and roughly how much for drive in drive out?
You would be crazy to use a vipec ecu in NZ, go to your nearest link dealer. If you can drive up to whangarei trickytune is a dealer and has done many pnp g4's
Anyone who tunes link g4's can tune a vipec as they are the same thing.
Btw GCP are the nz vipec dealer.
Edited by megrac
can anyone confirm that the v44 plugin will run low impedence injectors without using a resistor pack?
I have heard they from different people that they will but have also read you need a resistor pack.
Anyone done this yet?
V44 only handles high impedance so you'll need a resistor pack.
The V88 handles both + it also has knock detection unlike the V44.
Graham West in Adelaide has been running the Vipecs on the skylines adn other cars for some time now. He's good but he's expensive.
Personally I'd prefer to grab the one install myself and have my own tuner tune it for a few hundred.
I remember reading some where the V44 handles external knock input so that may be another option. Really comes down to the price of the V44 plugin vs V88.
I'm a bit of a fiddler so I'd love to ditch the PowerFC, plug the Vipec in with a wideband/laptop and get that tune 11ty billion percent spot on. :D
Edited by TheRogue
    • That R31 was so cool. Only did Orange Park once. Scared the hell out of me.
    • Selling my TE37SLs since I've switched to smaller wheels.  They're for sale in Japan but it's pretty simple to send them overseas; USA excluded, since JPPost isn't sending there at the moment. Specs Front: 18x9.5j +22 5x114 Rear: 18x10j +20 5x114 Price: 320,000 JPY/ 3,285 AUD (current FX rate) Condition: a few scratches here and there, no bends, distortions or cracks.  Tires will not be included for international buyers, I'll get them dismounted before shipping. They're currently listed on yahoo auction and will be shipped in Japan with the tires if they sell here. Shipping costs to Aus: EMS (1-2 weeks): AUD 1,175 (current FX rate) Sea (2 months): AUD 460  (current FX rate)
    • The alloy coolant reservoir has a sight glass, so as long as I can see coolant in the sight glass it's GTG, as for PS, it isn't anything catastrophic if it gets low, and as it hasn't lost a drop since I have owned the car I cannot see it being an issue, even after putting the "big block" 2.5 in....LOL The only time it gets slightly messy is at oil changes, as the oil filter sits above the frame, and I need to use a plastic bottle with its bottom cut off to catch the flow when loosening the filter
    • Good on you for taking on the job, but it is a big one. Even if you have bolt on manifold and turbo, you will need: Post throttle pressure source to boost controller to wastegate (and FPR, and ECU/MAP sensor) Pre throttle pressure source to top of BOV(s) Oil feed - you can take that from the standard port in the middle of the block Oil return to block under the turbo - this is much trickier than it seems to route a decent/wide pipe past the manifold. You really can't use rubber hose because it is way too hot there, and also the oil out of the turbo core is a bit frothy so it needs to have a decent diameter Water feed - you can take that from the standard port in the rear of the block. Water return - mine runs to a T into the heater box return, just make sure you don't create a high point making bleeding hard. All of those lines should use 200 series style teflon braided hose with heat shielding because everything needs to be routed past the manifold. Also a turbo beanie is a really good idea to minimise the chance of the car catching fire (under bonnet lining in particular) You also need to decide a cam cover breathing solution as well, will you vent externally via a catch can (probably illegal) or return to the intake (plumbing required and can oil up everything over time) Keep in mind the intake and exhaust piping in the engine bay will be custom so you either need to be able to fab ally and steel or have someone you can get a car that isn't running to. Get the wideband fitting welded into the dump pipe at the same time. Also, just my opinion, a screamer pipe attracts attention and doesn't add power, I'd plumb it back if you want to be allowed to keep the car on the road. BTW do you know anything about how healthy the motor is, and what power you are targeting? Doubling or tripling the factory power on an unknown motor is a little risky. Also fuel system will need some attention (pumps, high current hanger, direct power and earth feed, injectors etc)
