  • Replies 895
the timber species Tasmanian Oak is actually mixed tassie and vic trees like vic ash mountain ash messmate etc but its labeled OAK cos European people believe that ash is a sub species.
Enough "oh but its a vipec not a link its a link not a vipec." more about tuning results please. i couldnt give a rats arse who makes it. just as long as its good and has the proof to back it up
i think 12 pages back we all agree it is good, ive used both Vipec and Link G4's with great success, but as said a page back if you have a PFC and expect to get more power just by changing over you are wasting your money.... check over the options and if you need extra functionality and are reaching the limits of your current ecu then i cant reccomend the LINK or Vipec enough as they are great to use and driveability is as good as a well tuned PFC remap etc, far better driveabilty than any microtech etc..
hey all
im about to put a r32 rb26 into my 33 gtst, i currently have a 33 gtst pfc, but from reading i presume i would need the r32 rb26 vipec to run this motor? is that correct, and then would also need a standard 32 gtr ecu to put the vipec board into??
hey all
any r 32 33 or 34 stock ecu case will fit the vipec board
the vi-pec board suits rb20/25/26
speak to alistair @ Autoworx or contact Lumpy (the distributor in WA) for any details
Edited by gazza750
i figured out why flat shift wasn't working for me earlier this evening, i must say its a good bit of fun now that it does work, though traction between gears is a bit of an issue.
how do you set it up? where were you going wrong?
Wire up one of the digital inputs to the clutch switch and set it up as a "GP Input".
Check that the settings are correct for the way you have wired the switch using the "Digital Inputs" tab at the bottom of the software. (this is the bit where mine was playing up the rising/falling setting was set incorrectly so it was activating as the clutch pedal was released rather than depressed which makes for an interesting drive)
Turn flat shifting on i have found that around 0.75 seconds for the cut period works well for me.
Then just setup what RPM you want it active above with what % of throttle you want it to activate over.
i found that my car with a fully functional stock BOV holds ~8psi (running 12psi) during the gear changes and the boost is pretty much instantaneous when the ignition cut finishes.
Edited by TiTAN
cheers man, will do that when purchase time gets closer
Just a wild question, its probably been asked before, but i couldnt be bothered reading through the 20+ pages.
Does anyone know if there are any decent tuners for the vipec here in Auckland, NZ??
and roughly how much for drive in drive out?
You would be crazy to use a vipec ecu in NZ, go to your nearest link dealer. If you can drive up to whangarei trickytune is a dealer and has done many pnp g4's
Anyone who tunes link g4's can tune a vipec as they are the same thing.
Btw GCP are the nz vipec dealer.
Edited by megrac
can anyone confirm that the v44 plugin will run low impedence injectors without using a resistor pack?
I have heard they from different people that they will but have also read you need a resistor pack.
Anyone done this yet?
V44 only handles high impedance so you'll need a resistor pack.
The V88 handles both + it also has knock detection unlike the V44.
Graham West in Adelaide has been running the Vipecs on the skylines adn other cars for some time now. He's good but he's expensive.
Personally I'd prefer to grab the one install myself and have my own tuner tune it for a few hundred.
I remember reading some where the V44 handles external knock input so that may be another option. Really comes down to the price of the V44 plugin vs V88.
I'm a bit of a fiddler so I'd love to ditch the PowerFC, plug the Vipec in with a wideband/laptop and get that tune 11ty billion percent spot on. :D
Edited by TheRogue
    • To back this up, I'm always looking on the outside, seeing the level, and then opening it up anyway, as I'm worried the level I've looked at, is more so a scunge line. Then you end up dipping your damn finger in it too depending on the type of tank you're looking at just to make sure I'm not going insane.   PS, Mark, polish up the none moroso one a bit and then give it a clear coat. The Moroso one looks to be way shiner (not mirror polished, just shinier) and it'll still look weird with the two different alloys beside each other. Either that, or Id probably paint them a flat black...
    • Good old Orange Park hey... 😛   f**k I miss that race track
    • lo, it was a death trap. Good times. Got any Fatz Drift Day DVDs still available?
    • Yes, overthinking. Many PS reserviors are completely opaque. Our Skyline ones, for example. Have to remove lid, peak inside, swirl the dipstick, try to remember how to read it, etc etc. Normal. Radiator overflows are often sufficiently opaque and scunged up that you can't see the true level inside anyway, and have to open and have a peak. Besides which, I replaced the (massively expensive, even back then) plastic overflow in my Alfa GTV, back in the '90s with a stainless one that I had a good fabricator make up to be dimensionally same-same, that looks remarkably similar to the Bogan's Moroso one above, and I never suffered any particular paranoia that I didn't know how much coolant was in it.
    • Looks great, but I'm always concerned that it makes it difficult to see what level the fluids are at. Am I overthinking this?
