Who told you that?
A complete goose.
And hence, you never take the car back and see someone else!
Recently fit parts installed and had a retune. Much better than before,I think it was due to a crack in the intercooler piping before.
For 21psi with -5s... You are sorta missing 50rwkw still. You can go the usual dyno variance 10/15 here there whatever, but 50 is a bit.
Not if it's running 21psi, you have the airflow for the power.
You can tune around the AFM limit to a point from a WOT point of view, I had 340rwkw out of -9 using the stock MAF (but that's another can of worms not worth opening).
Somethin just does not make sense really.
Hope they don't ripsss you a new one, hey boiiii.
I would still suggest you learn what VCT is, whatever the engine you end up building.
i have a rb26 so i will use the head off of that . rob at rips is building my engine
Trent and I are both talking about VCT or CVVT on the 26 head, there are a few options available, including making it work yourself.
CVVT on my VQ25 is good for 800rpm better response, or the equivalent of running a VQ30. Incorporating it into a 26/30 would perhaps make the ultimate RB.
    • Based off what you’ve said here, I think I’ve figured out a good bit of what I’ve done wrong -  So on the line going from the PCV valve to carbon canister, there’s a T joint that is pretty much right next to that lower port - I hadn’t noticed that the hose in the diagram was curved to attach onto the carb, so I was putting that line for the lower port onto the PCV line / carbon canister line instead. I’m going to have a flick through the manual again tomorrow and should hopefully find a diagram that’ll show me where that T joint should be connected to. Timing also 100% needs to be sorted out as well, should be able to tackle that tomorrow as well. Definitely feel like I should be on the right track now though.
    • The screw is for idle (pilot circuit) mixture adjustment. Else, I'm confused ~ the diagram shows 2 carby ports, and the intake manifold port, but you're suggesting the "2nd port on the back of the carb that isn’t mentioned in the diagrams" ...yet, both carby ports are shown...que?... ...in any event, that port should be connected, but if not (like it is now), it's unlikely to cause a backfire out the carby (it would introduce false air and give you a fast/lean idle) ...sounds more like timing issues/spark plug wire routing responsible for the backfiring.
    • That's fair, I can see both points. I get enthusiastic when I see the FS section has a new post and want to see what interesting thing someone is selling. Then I get deflated it's a bump of a 10 year old post. Ha ha
    • Couple of litres of moonshine from his southern cousins would do it...
