I can't make up my mind ....
Should I get a wet nitrous kit for my FJ20ET S12
or
Should I get a better turbo ?? eh GT 3071
Car has been build for Track, Drift and Drag - a combination of all three.
Current turbo is a hi flow steel wheel Nissan turbo of a VL commodore - high mounted with an external wastegate
Estimated power will be about 230kw at the wheels in current form.
A 3071 should push that up to around the 270 mark
But would love a shot of gas - just because I haven't done it before - seems like a silly reason - but I'm all for trying new things....
whadyareckon ?
https://www.sau.com.au/forums/topic/222323-nitrous-or-bigger-turbo/
  • Replies 71
The car will only ever be used (driven to and from) the track or circuit.
Considering the Turbo will be about $1500
and Nitrous will be about $750
The turbo won't cut circuit times that much - brakes, suspension and tyres will do that.
The Nitrous could cut second(s) off 1/4 mile times.
Hmmmmmmmm
Nitrous is very hard on gudgeon pins...bigger turbo please.
ive just done the same thing...tossed up between putting a bigger turbo on our set-up and turning on the gas (i already have a kit installed in our car)...i went with a bigger turbo ;)
    • Even more fun, leave all the ADAS stuff plugged in, but in different locations, hopefully avoid any codes!   And honestly, all these new cars with their weird electronics. Pull all the electronics out Duncan, and just shove an aftermarket ECU and if needed a trans controller in, along with a PDM. Make it run basic but race car styled!
    • To follow up a question from earlier too since I had the front bar off again (fking!) This is what is between the bumper and the drivers side wheel And this is the navigator side, only one thing but its a biggy! So basically....no putting coolers in the wheel arches without a lot of moving other stuff. Assuming I move to properly race prepping this car I'll take that job on and see how the computers respond to removing a whole bunch of ADAS modules
    • So I prepped the car for another track day on Wednesday (will be interesting to see coolant temps post flushing out and the larger reservoir, with a forecast of 3-14 being 20o cooler than last time I took it out). Couple of things to mention; since I am just driving the car and not taking a support vehicle, I took the rear seats out and just loaded the back up Team Trackday style. Look at all that space! To cover off removing the rear seat....it is weird (note the hybrid is probably different because it wouldn't have folding rear seats) Basically, you remove the lower seat base, very similar to a r series but it is a clip that pulls forward to release the base rather than it being bolted down. Easy Then, you need to remove the side section of the rear seat on each side. There is a 14mm head nut at the bottom of the side piece, the it slides upwards off a hook at the top to release; you also need to unhook the seatbelt from the loop at the top. Then the centre piece is weird. You need to release/fold the seats forward with the tab in the boot on each side From there, there are 2,x12mm headed bolts holding the rear of each seat to the folding bracket, under the trim between the rear seat and the boot (4x christmas tree clips there, they suck). The seat is out but you can see where the bolts attach to the bracket
