  • Replies 204
Posted Images
Yeh once the car is finished i will be buyibg some 18" rims for the street. Will be either satin black FR18s or bronze TC105s. If the TC05s i have fit then the new RE30s i have at my desk in Melb will get flogged off. :) I regret buying new rims which before i have had a chance to fit have become common :(
Opps OT. How about a well designed wheel will cool brakes better then a 18" chromie wheel :)
yeah I think the weds we have troy are the TC05. not the 005.
these are the 005s. (i like them too. weds are the goods. all of them! just a shame not all of them are forged, like the XD9s etc, look nice but cast...).
I think they should be ok. When I insert the spigot part of the drawing into the gap in the wheel up to around half way there is clearance, but if I push it in all the way the 'caliper' touches on the rim slightly.
I'd check it out in person to be 100% sure
Thanks for checking. I'll get the brakes fitted and trial fit as everyone is suggesting.
Well, my brakes turned up today. Pics attached but I'm sure we all know what they look like. Rear hat is aluminium which is nice. Everything came as it should have done. Now for the fitting next Monday and then 1000kms of normal driving before they get onto the track. I've got 2 weeks to do this in before I'm at Sandown.......
Funnily enough, the recommended (by the vendor) run-in procedure is simply 1000kms of raod driving. No hard stops. No getting them hot etc.......Seems contrary to what I've heard, but his view is that only old pads needed this approach and that only old blokes still advocate it.....Hope that's not too controversial.
Got to get the coils changed too. Hopefully get them tomorrow from Slide.
In my dreams. They're in the sanctuary and sanctity of my office. I'm wondering if she'll notice once they're fitted. The irony is she has absoluitely no interest in my bogan-mobile but she seems to spot stuff with a hawk eye........ :) and keeps mentioning some 'secret fund' she thinks I have..... :D
Must be brake week.
My stuff went in on the weekend. Can't say if it works yet as I haven't done the other end. Just the M/C & front rotors & callipers. They will shortly be hiding behind these puppies..... :)
So your stuff has gone to a good home, Troy.
Not sure if it helps in the braking stakes but the brand whore count is heading North. :D
Im running Project MU single piece slotted rotors with Project Mu Titan Kai Front Pads and Project Mu HC+ Rear Pad's. No troubles pulling it up on the street with 400 KW at the treads at my disposal. Abit noisy though :)
9 pages later here they are. Funily enough I'm more excited about how they look than feel right now. Pedal is slightly softer than was (probably more piston area with the 4 pot rears) but they seem to work great on light and medium application. No sqeal so far.......Obviously not had the chance to stand on them from high speed so news on that is TBC.
I feel like a kid who had too much cake at the party. Over-indulged, but completely satisfied......
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
