anyone (other than sydneykid) using castrol oils?? getting some Formula R synthetic, 10W60 coming in, and will be trying that.
clock says 110,000 but i bet its more like 210,000ks.
got some cheap 20w50 runnning in it at the moment, only idle, not yet driven and the new oil + filter will be going in on the weekend.
any xp with castrol?
steve
I use Pennzoil 10w30, which is what was recommended by the guy who rebuilt my engine back in March 05. Can't say I have had any problems with it....Just under $30 @ repco for 5 litres. As my car is driven nana-style most of the time (daily driver) and I do alot of km's like this, I tend to change it closer to 10,000km's. Which is between 4 - 5 months of driving for me.
steve
I pretty much always use Castrol, in a 10W60 - but mostly because I haven't yet installed the oil cooler I bought. The oil gets quite hot at he track, so the 60 high temp viscosity rating makes it attractive. All else being equal, a 5W50 grade is probably a little better matched to the motor. Have nothing -ve to say about Castrol oils.
The thing you need to remember is the rating of the oil. When the GT-R was released, ie late eighties the oil grade was something like SF or SG or thereabouts. Now it is SM or similar. Each change from SF to SG and so on is a quantifiable gain in the protective qualities of the oil. So just about any current oil will be markedly better than what was put in the engine when it was released.
i have a oil cooler installed, so the 50 would be beter than a 60? what about the high k's on my engine?
steve
Yeah, the lower viscosity will give you a slightly lower pumping loss on you motor & make life a bit easier for the oil pump.
Don't worry about the kms - if you are at the point of having too much blow by or rattles or whatever then no oil, no matter how good will help. You can't save a sick engine with an expensive oil. If the motor is still ok then that is all good.
Is the Pennzoil 10w30 synthetic or mineral? If it's made of mineral than that's not really a good choices for a high temp turbo charge engine. Mineral do shear and have lower HTHS (high temp high shear) figure that synthetic oil plus lower flash point too. In the long run it will coke up your turbo and shorten it's life.
IMO the best choice of oil will be POE base stock; oil like Motul 300V, Redline street oil, Fuchs silkrone. Got excellent HTHS, additives package and higher flash point.
2nd choices will be PAO base stock oil like Mobil 1, RP or Castrol SLX.
Edited by Trex101
  • 3 weeks later...
I get my car serviced at Repco. They used "10w30 Cfx engine oil" at $32.51 for 5L. Doing a search on google this looks to be Fuchs Titan CFX which is apparently a mineral based oil?? Would this be okay?
My car is a NA R33 with RB25DE engine.
It will be fine for a NA engine, infact any API SL oil like Titan CFX can go 10K OCI with no problem at all.
im using Fuchs Tital performance plus (it says synthetic fortified motor oil on it) 15w-40 for my run in.
its not running yet, should i go get some mineral oil for it?
That's a semi so it's ok to run in your engine. Just take note to change the oil out at 500km or max 1k
I found that Pennzoil Synthetic had a wider viscousity range that I thought would be suitable for my car as it has quite a few km on it. Quick flow at cold startup & a bit thicker when hot for an older motor.
SAE 5W-50 for about $55. No complaint as yet, but I haven't compared it to the more expensive, harder to get oils. I've been using it for about a year.
Same here ! Pennzoil Full Synthetic 5W-50 for the last year or two and no problems. I Use the OEM filters.
I think as long as you don't forget the OEM spec, and work around them, you can't go wrong far wrong.
NISSAN recommend their oil which is 7.5W-30 from memory with 3,000km oil change intervals for a GT-R in Australian conditions. So, anything that has a cold weight of 7.5W or better ( eg 5W or 0W ) and hot weight of 30W or better ( 40W or 50W ) should do the trick.
But like someone has already said, having ENOUGH oil is THE most important thing.
I did an oil change on saturday using Mobil 1 which is 5W-50
Supercheap had a sale so I picked 5L up for $52 down from $65.
Last oil change they didnt have Mobil 1 so I went with Shell...Extreme... Optimax...Ultimate......Supreme......
I have no Idea, Shell something ;)
It's not really a good idea to use such a wide spread engine oil of 5w50 due to it's high VII content, you should choose the smallest wt spread like 10w30 or 15w40. Currently 5w20, 10w30 or 15w40 oil wt use the least VII in their oil formulation.
http://bobistheoilguy.com/oilshear.htm
  • 2 months later...
Redline 5w-30 for me in all my cars...costs more but lasts longer and is much better than all of fthe above...better HTHS rating etc and not going to go into it here there are a few threads on this in the past. in fact their 5W30 has a better HTHS than 0W40 mobil 1...which basically means its protecting ur car better at operating temp than the thicker oil! work that one out...The oil film strength at high temp are stronger than most 40w fully synthetic oils on the market.
50 and 60 ratings are too high and u will loose HP at high revs...but might make ur tappets quiet...
Redline simply make the best product....if not Redline...use the Motul V300 series...bit cheaper and still good.
How much have you guys been paying for a quart of Redline over here?
This is what we are getting for in Spore.
mxtradings
pretty similar with the conversion....I think it was u that put me onto it in the first place! and after doing some research and giving it a go I reckon its def. better (if u can afford it)
Edited by khunjeng
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
