This might be of interest to those of you who like objective information; i've made a small table with some oil specs on it.
If anyone can find Motul specs PM me and i'll update the table. If anyone can tell me how to make an html table appear in a post, PM me. Pasting the HTML didnt work.
http://www.jaftan.com.au/skyline/engine/oilspecs.html
Rgs,
Kot
hey great information however there wasn't much talk about the VII content of wide spread multi-grades...i.e. as an eariler post by TREX01 stated good to keep the spread as close as possible i.e. 10w30 or 15w40...
are there any other opinions on this?
I do know that some oil like Redline 5w20, 5w30, 10w30 & 10w40 do not contain VII. The 5w40 may contain some or little VII.
Some Infor on VII and the shearing effect
Bobistheoilguy
Bobistheoilguy
yeah I read that exact website after I posted it! however for other "full syns" which many are based on mineral base stock do...the HTHS rating should indicate the amount of VII addatives on wider spread oils I guess.
after reading al the stuff on the link it was quite intresting....worth a read if you want to understand oil ratings better. Most intresting were some of the comments about the cold start and operating temperature viscosity of of 10w30 Vs a 15w50 for example...
Edited by khunjeng
I USE Motul Turbolight 4100.
Have used many oils before and Motul is by far the best. My engine still idle's beautifully and the car runs smoothly as if its still new (its a 93 model) and its done well over 120 clicks now. As long as you put good quality oil and change it every 5000 clicks, it should be running like new. RB's are bullet proof if you dont do stupid mods.
Anyways Motul Oil is my choice Unless the engine is heavily modded and used as a Track car i cant understand why you would use any other oil!
and besides, its French hehe.
as there are no defined specifications (that I can find) for Motul I can't really see what the difference is between the Turbolight and the 300V series are. It appears the 300V range is promoted as thier "double ester" and assume it has a higher ester content than the Turbolight which may infact be a PAO base stock...
Motul are very lacking on their specs...intresting. By no doubt their oils are all good quality.
lol I sound like trex01 now...hehehe
Do you guys have access to UOA kit? This will tell you the avg from the good.
khunjeng, Turbolight is just a semisynthetic. like GTX Magnatec etc. Nothing out of the ordinary about it really.
I suspected it was a PAO base stock...so yeah...I would not recomend its use over the 300V or other ester based products
Edited by khunjeng
check this oil out guys, $80 for 5 litres but seems to be worth it.
http://www.royalpurple.com/
Have seen some tests done on this and would like to get hold of some.
Can someone tell me where to buy Royal Purple Online?? I cant get it in my area?
dunno this product is a bit lacking on specific info regarding what base stock they use.
Edited by khunjeng
They are using mainly 70-80% group IV PAO couple with 20-30% mineral additives carrier oil. They are pretty good but not quite a long drain oil. 10k is about max it can go.
HEY LADS,
I HAVE NARROWED MY OIL SELECTION DOWN TO 3:
MOBIL 1 5W/50
MOTUL 300V
MOTUL 8100 5W/40
my car is a 1994 R33 GTST, 126,000kms, manual.
which would be the best reccommended oil for my application.... up to now i have used MOBIL 1 but maybe its time for a change...
which is the best of these 3 for my car?
Also if i switch oils from Mobil 1 to Motul 300V or Motul 8100 5w/40 will i have to perform an engine flush to get rid of all remeins of Mobil 1?
any advice appreciated.
Beef
Edited by Beef
Geez this is an old thread good to see it revived.
We have conducted a heap of testing more recently again, testing in particular the SIn Penrite range and let me tell you don't overlook this stuff it shi.ts all over anything they have ever offered and competes better than some oild that were priced at double and tripple the SIN cost. Really recommend this oil its really good stuff!!
turbolight is a pretty average oil. that's why it's so cheap. it's a semi-synthetic oil. the 300V oils are 100%synthetic ester.
ok mate...yeah thats no so special really...not compared to the products we have been talking about.
Trex...one thing I'm not clear on is the group IV ratings...can u explain that a bit more...I'm pretty much down with everything else...type of PAO I assume.
Ok, since you asked. Here are 2 link which talk more in depth into group I to V base stocks. :D
Base stock
Base stock 2
Edited by Trex101
    • Please use a modern ECU. PowerFC with the Nintendo Gameboy controller is horrible. It's not 2005 anymore.
    • The car/ECU will have all the sensor that it needs and expect to have. I think i do not have to explain to you how the Link is way better specialy if you have swapped engine   I just do not want to deal with any "problems" cuz i have only Nistune which i learned is not that great and in my case cant even deal with that speed problem (Link can) And of course it will be way more easier to tune and diagnose and safe. And for the ECU/speed problem...i dont know.
    • Per Mark Roberts of Sonictune: Mark Robert Author At this time, no. No ETA either 2016-17 models. You will be able to purchase and install a 2018.5+ TCU though   TCU purchasing and pricing info! As we near the release of TCU tuning, I am going to answer some questions I get asked often.   What do I need for TCU tuning? At this time, you will need a 2018.5+ TCU to be able to tune. If you have a 2016-to early 2018, you will need to replace your TCU with the newer version. One good way to know if your TCU is good is if you have auto upshift in manual mode in 1st gear around 6500 rpms. If your manual 1st gear goes to 7k rpm and will hit the rev limiter unless you shift, you have the older TCU.   Why do I need to buy another ecu license/phone flash if I already have it on my ECU tune? The TCU is its own computer module. It is completely separate from the ECU. Because of this, you will be required to purchase a TCU license and, if your tuner has it, the phone flash license required to tune it via phone/bluetooth.   Do I need TCU tuning? TCU tuning is NOT required. However, the faster your setup, the more it will assist in track and dragy time consistency.   If I’m ECU tuned by (tuner A) can I get my TCU tuned by (Tuner ? Yes, since it’s a different module and a completely separate flash, you can have two different tuners. However, it is highly recommend that you have both tuned by the same tuner. For me, my TCU tuning will directly complement my ECU tuning style and features and running my ECU and another TCU or vice versa MIGHT cause some issues. At this time and for the foreseeable future, I will only be tuning my current ECU tuned customers TCUs.     I have a SYVECS AWD controller. Do I still need it? Yes! The AWD controllers main job is to control your AWD system. However, with TCU tuning, you will no longer need the auto-shift function as that will be done through the TCU. The AWD controller will still be very beneficial for racers looking to maximize traction on the launch.     Shift schedule changes: holding gears longer at lower pedal input as well as max shift rpm changes. Please note, the new ECU race rom coming out will address 90% of the shitty drivability issues these cars have through custom maps from myself and Racebox—as well as others I am sure.   Increase shift speeds: as seen in the videos I’ve been posting, the TCU shifts much faster once tuned.   Increased shift pressures: as also seen in the videos, much firmer full throttle shifts.
    • The fancy pants red shock tower brace is finally incoming from MX5 Mania, getting it shipped from 'Merica has been a long and problematic process, and GWR, the 'Merican supplier will not ship directly to consumers outside of the US, Mania basically had to order a heap of them, the colour choice was silver, or red, and we all know anything red adds 5 killerwasps of dynotorques..... Whilst it does fit over a 2.5, and I've seen a few photos and videos of it being installed and fitting, google also says it might get real close to the FAB9 intake front runner, people in the US says it does fit with the FAB9 intake, except for one person who said it slightly touched.......so there is that.....LOL..... As it seems that I am the first in AU to have this combination of parts there's no local knowledge about fitment, so I'm just a willing guinea pig in this endeavour, I'll cross my fingers and toes and hope for the best In other news, I ordered stuff from China  on the same day I ordered the 23° silicone bend from Victoria, the stuff from China arrived a day ago, the 23° silicone bend is still travelling around Australia thanks to Australia Post, and "may" be here next week
