For that budget, go for Delvac 1 5w40. 5L should be enough for RB25 rite
Yep, the RB26 is about 4.75 litres total. Takes about 4.5L first, then when you start the car oil fills the reserviors and oil filter so the sump needs a bit more.
oops sorry
the car has done just over 70k
I'm a bit of a lead foot
Driven Daily..small trips... with roughly 100k trip a fortnight.
Just drove it over 2000k across the nullabor with no oil consumption.
Oil is black :no:
Doing oil change this weekend :happy: With a bit of help :)
I know it might be a bit late as you may have done your oil change but,
I was running castrol 10w 60 and changed to a castrol 0w 40 best change i have done. it starts better and the motor runs cooler by about 5-10 degrees less. What i have read from this forum is the 10w 60 is mainly for high kms and race cars.
Edited by subzeroR33
stagea girl. just buy a 4 litre, and a 2 litre of the 300V. yes it's more expensive, but it's a far, far better oil and i think it's better value when you consider the difference. plus your first oil buy will be expensive (need 6L) but then next time you only have to buy 4 :P
  • 3 weeks later...
Castrol EDGE is just rebranded Formula R. Not a single word was changed in the specifications in the PDS's from what I've gathered. But how knows, they might be different.
But yes being synthetics (well API Group 3 base anyway), they are much better suited to our cars than a semi or mineral oil. I still would say they are not as good as Mobil 1, judging by their specifications. Only their 0W40 would be the exception which would be comparable (being API Group 4, ie PAO).
I've trialed EDGE 5W30 in my car as 'flush'.. seems to be working well so far.
man all this oil talk makes me feel guilty coz i just changed my oil with repco brand semi synthetic 10w40 thinking it has the same weight etc.
what do u guys think about that oil?? (anyone here actually ever used it, i know its pretty cr*ppy)
eng: rb25det(turbo back zorst, pod filter)
change interval: every 5k
driving style: granny street driving (occasional heavy foot)
oil consumption: b/w H and L from H after 4k
from what i've read so far Mobil delvac1 and Motul 300v is real good but a bit pricey, so im going for value and choosing Castrol Edge 5w30 for my next oil change, is that good enuff?
many thanks in advance
aquariuz6, yes IMO their 0W40 is the best out of the EDGE range and I would recommend it.
vbdotnet, well being Repco, what can I say. Will do the job for at least 5,000km intervals. I'd give the EDGE 5W30 a go on your next change. Devlac is too hard to find (although its easy for me) and 300V is a bit overkill for your R33 with the usual mods.
im uainf Mobil 1 15w/50. And im a mobil man.
please note Castrol do not make their own oil they sub contract it out. Well this info is about 8yo so i dont know they still did the same thing or not. Castrol do not take out the carbons in the engines out . thecarbons stays in the engine thus when you switch from castrol to mobil the engine shits itself. cos mobil oils takes the carbons out
Yes Delvac must be extremely hard to find if no one has answered my question as to where I can find it in Melbourne that was asked twice LOL :)
After lots of reading and searching I'll be going Delvac 1 next change, especially if I can get it at a decent price.
The old motul 8100 5w40 has jumped up in price it appears, I used to be able to get it for $60 now its jumped to $69. :)
On another note:
Spotted Pennzoil Platinum with its little 'made in the USA' sticker at the local repco store.
Interesting find.. First time I've seen it in AUS.
The old motul 8100 5w40 has jumped up in price it appears, I used to be able to get it for $60 now its jumped to $69. :(
On another note:
PP got pretty good review over in BITOG, it make up of mostly group V (not ester but EOP) base stocks. If it's cheap just use it.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
