I too am keen to hear this, how is it to drive?
speaking of RB20E, i one had a skyline with an RB20ET, i bought it thinking it was a RB30DET cause it looked like one under the bonnet,
Didnt drive that bad really until the auto decided to start slipping and then found out it was running 1 bar of boost. lol..
You actually broke a spanner? What was it plastic! Lol surely you would round the sump nut before breaking either of those. Also a socket doesn't have threads haha.
Remember this rule, lefty loosie righty tighty and you can't go wrong.
Those do sound like cheap tools...
Sougi is done and dusted kids, don't bother asking me for it :)
Still have some bottles of M5000 left but can't be assed posting interstate...if you live local in Melbourne you can come get it off me, otherwise go to hell and wait for Syn 6000 to be released!
Lol yeah they were pretty cheap, I thought it was on too tight so ended up using my foot to push the spanner and try and undo the bolt but it snapped and I nearly sliced my foot open... Probably shouldn't be telling you all this, I'll just get teased lol
Not gonna lie to you mate, for various reasons it takes me fking AGES to do oil changes too. Not so much because I'm newb at it (done plenty of times) but because I'm simply retarded.
FWIW :P
I'm just compulsively clean...gotta clean all the crap the old filter spills out, wipe the sump, get every last drop of old oil out...have that oil level at exactly the same lol.
buy one of the $16 bottes of gw from supercheap
drain the old stuff
put in the cheap stuff
run it again
put the dirty stuff away
drain the cheap stuff
put the good stuff in and keep the cheap stuff for another clean
How do you guys get every last nasty drop out?
Undo sump plug, go have beer, cup-of-tea, have a chillax, change filter etc... Then do up plug and keep going.
Do you go so far as tilting your car and dry cranking the motor for a second??
Prolly would skip that step.
Do you use a flushing oil?
Some people swear by it, but it's not necessary if you're using decent oil and changing it regularly. Not all carbon deposits in the engine are the "devil", any deposits for example smoothing out imperfections in the cylinder lining will be removed, which will subtract from engine performance and longevity.
    • Onto the rear lower shock mount. It's worth starting with a decent degrease to remove 10+ years of road grime, and perhaps also spray a penetrating oil on the shock lower nut. Don't forget to include the shock wiring and plug in the clean.... Deal with the wiring first; you need to release 2 clips where the wiring goes into the bracket (use long nose pliers behind the bracket to compress the clip so you can reuse it), and the rubber mount slides out, then release the plug.  I found it very hard to unplug, from underneath you can compress the tab with a screwdriver or similar, and gently but firmly pull the plug out of the socket (regular pliers may help but don't put too much pressure on the plastic. The lower mount is straightforward, 17mm nut and you can pull the shock out. As I wasn't putting a standard shock back in, I gave the car side wiring socket a generous gob of dialectric grease to keep crap out in the future. Putting the new shock in is straightforward, feed it into at least 1 of the bolt holes at the top and reach around to put a nut on it to hold it up. Then put on the other 2 top nuts loosely and put the shock onto the lower mounting bolt (you may need to lift the hub a little if the new shock is shorter). Tighten the lower nut and 3 upper nuts and you are done.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
    • Yes. Autos typically work from the speed sensor on the pinion shaft of the diff. I also think that even if you have a proper speed sensor for the bog manual in the manual box, that the signal it outputs is not compatible with the auto dash anyway. You should consult that manual (the book, not the gearbox).
