I just went and bought the Gulf Western SYN-X-3000, damn its so cheap at 30 bux, im feeling guilty lol and wondering if I should go n swap it for the 'better?' Sougi M5000 which is what I have in my engine currently...
Double post damn iphone.
Edited by rondofj
In the $30~ range I would only touch GW or Penrite. If you put something in like Magnatec then I would say to swap it out immediately for something better.
Oh ok, just bit paranoid cos it ( GW SYN-X-3000)looks kinda generic, but have read on hear that its pretty much the same as the GW Sougi M5000 which is only 50 bux.
Edited by rondofj
I use Sougi S6000 (still have supply for one more oil change) and as far as it went with replacing my regular oil Motul 8100 X-Cess, I couldn't fault it all. Good oil pressure when cold and hot, built pressure quickly at startup, still looked good after I dumped it at 5000km (no sludge, was black but didn't stink of fuel), idled smooth as it did with Motul (often I had to check my RPM while waiting at traffic lights as I couldn't feel it idling, kinda felt like the engine had stalled).
Years before I even heard of Sougi, I had some cheap GW XMP ($5 something at supercheap) lying around I never got around to using as I had a 4 cyl shitbox before my skyline, I offered to do an oil change on my neighbours car (4cyl shitbox). It was a completely different animal putting the oil in, before it violently shook, could feel it through the steering wheel really bad just idling and the loose plastic interior panels sounded god awful not to mention the engine sounded like shit. After the change, engine sounded healthy again and idled smoothly which god rid of that nasty vibration.. I wasn't expecting this at all from what I perceived as nasty $5 oil. Even my neighbour thought I did more than just change the oil and filter.
These 2 experiences personally give me have confidence in the GW brand, I only use it in my skyline because others have used it with success.
If I run out of S6000 and Syn-X 6000 isn't available nearby, I'll give Penrite's 10 Tenths range a try, if that doesn't work I'll go back to Motul.
Nothing wrong with running Syn-X in your car. It is technically a "better" oil than M5000 only because it meets later specifications (SM vs SL from memory). It is IMO the best oil on the price-quality scale and I used to sell lots of 205L drums to mechanics who loved it because of how cheap and versatile the oil was. They all used it in their regular customer cars and upon return couldn't fault it. I'll still be using M5000 once I run out of S6000.
Birds that new Syn-X 6000 looks interesting. Not so happy about it being 5w though. I think it should have been a 10w40 oil as it's still going to be competing with the Royal Purple, Motul 8100 X-max 10w40 and the Chrono 300V. It's not a bad replacement for Sougi S6000 but it's annoying that yet another oil comes in a 5w40 only with no 10w40 option.
I was a little disappointed when I saw that it was 5w...don't know why they couldn't just do a full synth version of Syn-X 3000. I think they wanted a cheap oil that would appeal to all these late model cars asking for 5w oils. That said, I've heard there's very little difference between 5w and 10w, and that some oil companies will market their 5w as 10w and vice versa because of this.
Hey all.
Need some advice on what oil to run when using E85. Has it been covered before? I hear that because of the ethanol content a different type of oil may be required. Thanks in advance.
russ, we had a long thread about it in FIP.
I use motul 6100 15w50 as it is desgned for LPG and has good moisture absorbing properties.
to summarise what we worked out, you can use pretty much any oil if you change it long enough. if you dont want to change it after every track day dont use 300v
a semi syn (like 6100) is a good idea as the mineral content will have good moisture absorbsion.
esther based oils are not great unless you change them after every event, as they end up with the moisture seperate from the oil.
there are specif oils that were reccomended, however i cant remember them atm.... i'll link you the thread when i see it
All of the Penrite HPR oils are fully synthetic now, what are your thoughts on this?
Would you switch from Syn to HPR? Or keep going with the new Syn (Ten tenths?)
I am trying out the HPR15 for my RB30.
yeh i been wondering the same..i just put HPR10 in as its cheap and only really seeing street duties and i was sick of spending 80 bucks on oil just to drop it 2000kms later cause it hadnt been driven much..
but wether or not its designed for engines pushing double factory power is something im unsure of as yet...Might be better off with the Edge :unsure:
Stock rb30 = coles motor oil changed every 50 000km's and it still wont die....
ARTZ, the HPR will be fine, i used the old HPR for years and years at double factory power and when i pulled the motor apart it was immaculate. I cant see the new HPR being anything but better again. But then again I'm a big Penrite fan so i might be a little biased.
Well First cold start this morning with me remembering i have forgies but really noticed alot more noise than i was used to also noticed even at quarter temp some engine noise was still there. Once car come up right up to temp the car was fine. I was just using the royal purple 10w 40w and i have the HPR10 which is however 10w 50w so any thoughts id really appreciate it.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
    • Yeah that looks like great caster, but I'd suggest trying less front camber some time and seeing if it helps with braking without reducing mid corner speed too much
    • I ended up setting the rear 5mm higher than normal to give some clearance.  My plan is to run the least camber I can in the rear which I think with the extra width is going to need to be -1.75 to -2.00° just to get clearance.  Guards have been rolled and pulled as much as they can/I would be wanting to.  front has the Acostal knuckle with the KPI change and the drop etc. So should be okay with the existing settings I have run with AR1s etc Front: Toe total -2mm(1mm out each side) Caster +7.5° Camber -3.8° Ackerman +15°
