Thanks for the input guys. Might start off with Mobil 1 or similar 10w40 and see how it goes.
good choice :yes: , i wouldnt bother with some high milage oil, just use the Mobil1 fully synthetic and see if it uses oil first.
  • 1 month later...
Anyone used those Shell branded oils?
Seems like the only thing I can find that is 10w40 from the local shops (the most recommanded spec from what I have seen) without paying $50+ onwards.
Car is just auto daily driver with basic bolt ons.
Edited by Mayuri Krab
would be fine.
People get strangely finniky about oils etc when really there is little need.
If your car is unmodified (i.e. major power and tune alterations), doesnt make lifter noise on startup, and doesnt use oil then a Shell 10w40 would be sufficient.
If you give it a regular bootfull and go to the redline then maybe think about at least a semi-syn, but otherwise, all good.
It's on special at the moment. Buy up guys. :P
Where?
also, this is a pretty interesting read!
http://www.animegame.com/cars/Oil%20Tests.pdf
Looks like penrite sin5 goes pretty well
Coming up to my first service :D
I've done a bit of reading and I was pretty set on Castrol Edge 10w 60 because RacePace uses it.
Here are my personal circumstances which may factor in.
  • Melbourne cold (start-up wear?)
  • Daily (And I live next to freeway so short period before on and 100km/h)
  • Track work
  • 240 rwkw
So basically I think I might need a lighter oil than 10w 60 oil to help with going from cold start to 100km/h in 1,400m warm up space.
Thoughts?
^ if its a rb with no oil flow/drain mods you should be using something thinner as thicker oil is harder to drain back to block /main bearings where most rb's fail. i fill my rb20 up to 6 liters for that extra protection that most do if they dont have oil control mods for track work.
been using motul 8100 5-40 for awhile now with no oil control mods although cant be arsed paying 80 bux a bottle anymore .
what are peoples thoughts/ experience with penrite HPR 5 5-40 full syn for limiter bashing and abuse compared to the motul?
Edited by Dan_J
Track work
240 rwkw
Thoughts?
Run what ever oil helps you sleep at night ;)
That said, I like to believe 10w/5w oils are fine, for our climate, I don't think there is a big difference in cold viscosity, but for your situation I would just let the car idle for a little bit to get the engine oil temp up so you are not getting to 100km/h on a completely stone cold motor.
If you have a oil pressure gauge it should give you a rough idea on how the oil is flowing through your motor, cold it should be high, as it warms up it should stabilize. Use this to judge when its safe to travel at 100km/h, if you granny it up, even on a cold motor it should be fine. I don't rev my motor more then 3k rpm when its cold, and keep it light on the throttle till oil temps are normal.
I am in no way giving professional/expert advice. Just from all the reading I have done, that's now my current opinion. I personally run 5w40 motul 8100
Sent from my Nexus 7 using Tapatalk HD
Edited by Booki
How much cheaper is the penrite?
Long as you drop it regularly I don't think it matters too much. You may as well go cheaper as I don't think the hpr range are a "proper" full synthetic group iv oil? Tho not 100% sure
Interesting point on the oil mods. I'll have to look into what oil mods there are! Feel free to recommend any.
Penrite synthetic 5 (5w 60) is another oil I was looking at
My PowerFC lists water temp, Could I use the water temp as a guide as to when it's "ready" ?
...I don't think the hpr range are a "proper" full synthetic group iv oil? Tho not 100% sure
Correct! The base oil in the HPR range is not a true fully synthetic - most other brands would label it "semi-synthetic". If you want a decent penrite oil, grab one of the "Enviro" ones :)
ok so i've gathered that the HPR 5-40 is basically motul 4100 or lesser.
now 'what are peoples thoughts/ experience with penrite Enviro 5-40 full syn for limiter bashing and abuse compared to the motul'?
its $20 cheaper then the motul 8100 and as i grab 2 bottles for my oil change that makes it a $40 saving.
http://www.supercheapauto.com.au/online-store/products/Penrite-Enviro-Engine-Oil-5W-40-5-Litre.aspx?pid=324403
Edited by Dan_J
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
