I've been running Penrite Racing 10 for almost 2 years now, no complaints
From what I understand, this is a Group 4/5 oil?
Deciding on if I keep using this, or switch to Nulon Full Synthetic 10-40 Hi-Tech, does anyone know what group this falls into, and if its any better than the Penrite Racing 10?
You would need to shoot Nulon off an email, I would like to know also. Prenrite state clearly in their product information sheets that Racing 10 is synthetic PAO and Ester based.
If you're looking for something a little cheaper, I have been using Penrite HPR DIESEL 5 5W-40 It has a high Zinc content as well as detergent/ cleaners, works well for me.
http://www.penriteoil.com.au/products.php?id_categ=1&id_fuel_type=3&id_products=7
Edited by Missileman
I drop mine after every trackday. :)
I do scaling factor for track day kays - so any kms done on the track are multiplied by 5. So if i do 100kms at the track, that's equivalent to 500kms of regular driving. At this stage i have no evidence if this is sensible or not...
The reason people drop there oil after a track day is due to the amount of heat the oil sustains when being driven on the track.
Excessive heat on any engine oil reduces its effective life immensely.
If you find yourself in the higher rpms at a track day, you should dump your oil.
Also keep this in mind on the steet. Pending how you drive.
If you want to know for sure. There are places that analyze your engine oil.
My track oil temp is under control. IIRC Mobil say M1 is ok with respect to degradation at 150 deg C. Agree that oil temp has a very important impact on oil life, as does quality of the oil. So whether you need to dump after a track day depends on those and other factors. As you say, if you dont test the oil you're just guessing, but thats fine too.
I've been doing oil testing on the Stagea, and will do on the GTR next time.
  • 3 weeks later...
Hey guys just here for some advice:
I have read through the first few pages and I have a slight understanding but in my 33 it previously had some cold idle issues and the oil pressure was hitting 8 when driving... So I decided to change the oil and after asking around I decided to go with penrite 15w-60, though when I started it it seemed to have the same idle issue.. (Had it on for 2 minutes before I stopped as I was worried about the sump plug, which the head of the bolt snapped off...)
Any ideas? Using this car as my daily/track car!
Also like in the hills of Adelaide so it gets pretty cold here
Edited by Polishn
    • It was a great, but typical track day, and some VB was ingested at the night time debrief 🤪
    • And so, to round this out, I couldn't be happier to confirm @MBS206 has decided to buy the car. He drove down from sunny QLD with a trailer last week and it is off to its new home today. I'll let Matt confirm on next steps but I understand broadly that the plan is to leave it pretty much as is, and just get some quality wheel time with a nicely balanced car that is pretty much track ready. There are a few a jobs still to be done first but nothing too major and I think its a very smart buy Dinner last night at the Paragon with a round of VBs (mostly) for Neil
    • Well, 50 pages and the end of a chapter for this car. We took it out for a shakedown at Wakie yesterday, and everything went well. There were a couple of niggles: - Oil cooler fitting leak - tightened, cleaned, stopped leaking - Radiator cap overflow fitting was leaking....Mark called it, the overflow fitting was threaded in and not tight....tightened, tested and held pressure - Small oil leak at the rear of the block, probably the turbo oil feed - too hot to get at it comfortably but probably just needs to be nipped up - leak at the driver's side rear brake line where it meets the hardline. Fitting wasn't loose, so Matt backed it off and back on, no further leaks - there's also a leak somewhere on the top of the fuel tank, maybe that cross over fuel line - that was has been left to fix when its on a hoist Otherwise than those niggles the car went great, turned great and stopped great so it was a very successful day out. I'm always really nervous when a car first hits the track after a long break, especially with a brand new engine as well but it was great. VID-20251011-WA0007.mp4  Big thanks to @The Bogan who dropped by and helped out, @MBS206 and my nephew Lachlan the apprentice.  Neil's wife Mel also surprised the hell out of all of us by dropping by; she's up in Tamworth these days but was travelling to Melbourne so had plausible deniability for turning up at the garage, it was great to see her but also obviously a bit sad all round.
    • Skyline R33 Series 2 sedan tail lights in excellent condition. These are becoming harder to find, especially in this state.    BOTH SETS ARE IN FANTASTIC CONDITION (REFER TO PHOTOS)    ✅ No broken covers or cracks ✅ Lenses are in flawless condition ✅ All rear mounting lugs intact ✅ Comes complete as pictured ✅ Perfect for restoration, replacement, or upgrade   These lights are ready to go, no surprises just quality OEM parts.   These are definitely one of the better sets we have seen in a while. With minimal wear and tear they will come as you see. Bear in mind they are not brand new they are almost 30 years old now. To find them in this condition isn’t easy they can only be obtained on the second hand market.   Australia Wide Postage Available At Buyers Expense. Silver Set:$850 Grey Set:$850 PM Me for purchase or any other questions  IMG_2166.dng IMG_2165.dng IMG_2172.dng IMG_2173.dng IMG_2174.dng IMG_2179.dng IMG_2180.dng IMG_2260.dng IMG_2258.dng IMG_2259.dng IMG_2261.dng IMG_2266.dng IMG_2273.dng IMG_2274.dng IMG_2276.dng
    • Unsolicited advice? Keep the engine as close to stock as you can. Nothing wrong with adding some boost and making a little more power, but given where you are, you really don't want to try to make it into a monster. I can't imagine the roads are up to it, and the lack of locla support when it grenades will be a ball ache. FWIW, If there is a dyno around that you can access, then brand new injectors are a good idea, which will lead you to (at least) putting a Nistune in it, which will allow you to put an R35 AFM on it, all of which will make it possible to make it much much nicer to drive and live with.
