I've been running Penrite Racing 10 for almost 2 years now, no complaints
From what I understand, this is a Group 4/5 oil?
Deciding on if I keep using this, or switch to Nulon Full Synthetic 10-40 Hi-Tech, does anyone know what group this falls into, and if its any better than the Penrite Racing 10?
You would need to shoot Nulon off an email, I would like to know also. Prenrite state clearly in their product information sheets that Racing 10 is synthetic PAO and Ester based.
If you're looking for something a little cheaper, I have been using Penrite HPR DIESEL 5 5W-40 It has a high Zinc content as well as detergent/ cleaners, works well for me.
http://www.penriteoil.com.au/products.php?id_categ=1&id_fuel_type=3&id_products=7
Edited by Missileman
I drop mine after every trackday. :)
I do scaling factor for track day kays - so any kms done on the track are multiplied by 5. So if i do 100kms at the track, that's equivalent to 500kms of regular driving. At this stage i have no evidence if this is sensible or not...
The reason people drop there oil after a track day is due to the amount of heat the oil sustains when being driven on the track.
Excessive heat on any engine oil reduces its effective life immensely.
If you find yourself in the higher rpms at a track day, you should dump your oil.
Also keep this in mind on the steet. Pending how you drive.
If you want to know for sure. There are places that analyze your engine oil.
My track oil temp is under control. IIRC Mobil say M1 is ok with respect to degradation at 150 deg C. Agree that oil temp has a very important impact on oil life, as does quality of the oil. So whether you need to dump after a track day depends on those and other factors. As you say, if you dont test the oil you're just guessing, but thats fine too.
I've been doing oil testing on the Stagea, and will do on the GTR next time.
  • 3 weeks later...
Hey guys just here for some advice:
I have read through the first few pages and I have a slight understanding but in my 33 it previously had some cold idle issues and the oil pressure was hitting 8 when driving... So I decided to change the oil and after asking around I decided to go with penrite 15w-60, though when I started it it seemed to have the same idle issue.. (Had it on for 2 minutes before I stopped as I was worried about the sump plug, which the head of the bolt snapped off...)
Any ideas? Using this car as my daily/track car!
Also like in the hills of Adelaide so it gets pretty cold here
Edited by Polishn
    • So.... the K&N air box thingo was too big, ended up gifting it to a mate, well, by gifting it he actually supplied food and beer at the pub,  which was nice, as it will not sit on a shelf in the garage for the next 10 years I did trim up some of the existing stuff to neaten it all up and gave it some wrinkle paint, unfortunately it currently has a used and abused mish mash of different types of hose clamps, 4 big fat T bolt type (shit), and a few normal clamps of vairing sizes and brands, but..... only until the 6 constant tension black worm clamps that I ordered from EFI solutions turn up next week Currently the current hose clamps are triggering me hard, LOL Is this the final version, probably not, I really want just 2 silicone pieces, a straight bit of silicone from the filter to the MAF is easy and will happen as soon as I head into Just Jap tomorrow, the problematic part is a 30° silicone bend from the MAF to the TB that I can connect the engine breather from the head, I found that there are bulk head fittings for boat bilge pumps that should work, but until I can get a 30° silicone bend the alloy pipe, and the 11ty thousand hose clamps, are there for the foreseeable future 4 hose clamps are golden, 6 are grudgingly acceptable, the 8 currently holding it all together is just taking the piss    I've also ordered 60 more retaining wall blocks for the front yard, I mis-gonculated the height that was required to get above the base of the Photinia's (red robin's) that are the hedge behind the front fence, currently it is 2 blocks high, and about 1/2 a block short, so going 3 blocks high will be above the base of the red robin's, and allow some room for mulch
    • It is the stock air box with the panel filter. Everything else is stock except the exhaust at this point, as I also went back to the cleaned 270cc injectors. I will check the RPM when the IACV is unplugged and report back.
    • As MBS suggested if this is happening when the engine is cold you're going to want to remove the intake air regulator and verify resistance + that the shutter is physically opening and closing. At -20C should be fully open, 20C half open, over 60C fully closed. At 20C should be 70-80 ohms. For AAC valve testing using a Consult cable see if you can raise and lower the idle by commanding more or less AAC duty cycle. Hopefully it's pretty linear as well, shouldn't be like 30% AAC valve is barely idling and 40% is 1500 rpm.
    • Bloody apprentices! 🙄
    • Not sure yet.  Was considering speedtek because it was rated to 800hp, but when I did some research about him I don't think I will go for that🤣 So maybe giken gear set, but I'm afraid it won't be strong enough🙄
