I've been running Penrite Racing 10 for almost 2 years now, no complaints
From what I understand, this is a Group 4/5 oil?
Deciding on if I keep using this, or switch to Nulon Full Synthetic 10-40 Hi-Tech, does anyone know what group this falls into, and if its any better than the Penrite Racing 10?
You would need to shoot Nulon off an email, I would like to know also. Prenrite state clearly in their product information sheets that Racing 10 is synthetic PAO and Ester based.
If you're looking for something a little cheaper, I have been using Penrite HPR DIESEL 5 5W-40 It has a high Zinc content as well as detergent/ cleaners, works well for me.
http://www.penriteoil.com.au/products.php?id_categ=1&id_fuel_type=3&id_products=7
Edited by Missileman
I drop mine after every trackday. :)
I do scaling factor for track day kays - so any kms done on the track are multiplied by 5. So if i do 100kms at the track, that's equivalent to 500kms of regular driving. At this stage i have no evidence if this is sensible or not...
The reason people drop there oil after a track day is due to the amount of heat the oil sustains when being driven on the track.
Excessive heat on any engine oil reduces its effective life immensely.
If you find yourself in the higher rpms at a track day, you should dump your oil.
Also keep this in mind on the steet. Pending how you drive.
If you want to know for sure. There are places that analyze your engine oil.
My track oil temp is under control. IIRC Mobil say M1 is ok with respect to degradation at 150 deg C. Agree that oil temp has a very important impact on oil life, as does quality of the oil. So whether you need to dump after a track day depends on those and other factors. As you say, if you dont test the oil you're just guessing, but thats fine too.
I've been doing oil testing on the Stagea, and will do on the GTR next time.
  • 3 weeks later...
Hey guys just here for some advice:
I have read through the first few pages and I have a slight understanding but in my 33 it previously had some cold idle issues and the oil pressure was hitting 8 when driving... So I decided to change the oil and after asking around I decided to go with penrite 15w-60, though when I started it it seemed to have the same idle issue.. (Had it on for 2 minutes before I stopped as I was worried about the sump plug, which the head of the bolt snapped off...)
Any ideas? Using this car as my daily/track car!
Also like in the hills of Adelaide so it gets pretty cold here
Edited by Polishn
    • I hope it's actually possible. This is a write off in insurance world.
    • Yup. 2-way with shallow ramp angles. Still works.
    • That was the first session so not a lot to take from the day. It was low 20s ambient and the coolant had got to 110 (and obviously had some pressure!) so that still needs to be addressed. I haven't downloaded the data yet but will. I had refilled the auto trans with Redline DT6 because it claimed the best viscosity I could find at 100o. It wasn't really long enough to get a good feel for that; while the trans got to 100o in the session it still wasn't shifting crisply as I hoped. I think I'll try a few more sessions before judging. No steering motor overheat but I'd hope not in only 1 session! But finally the suspension; it was night and day over the standard stuff and the car was a couple of seconds quicker on the same crappy tyres, which is a huge difference. I'll stick with that and get some sway bars and a mechanical diff sorted too and see how that all goes together
    • I guess it’s partially a compromise of how my car is used, wanting to be able to switch from drift to grip with track side on-car adjustment. Also partially with the way the knuckles are set there is more static camber but less dynamic camber gain.
    • OK, so update from the track day on Friday It was a classic "an unfortunate series of events'. There were a few cars around and when i checked my mirror coming out of the fish hook I notice some smoke from the rear of mine. Looked again and it was getting much worse, I figured I'd blown a turbo or something to got off it and pulled off the racing line. However.... since it is a left hairpin into a right kink, I was on the inside of the next corner. There was a car passing me on the left and a big drop off over the ripple strip on the right......and someone had knocked the witch's hat that was on the apex about 1m onto the track. So, between those 3, I decided to mow down the cone and not damage my car/the other car. Right choice, but surprising result.  The car decided the cone was a small pedestrian so it blew the rear bonnet hinges up to protect their head in the upcoming person to car impact....I didn't see that coming and like an airbag deployment it happened super fast. Straight into the pits from there, everything was driving fine but it became clear it was a coolant leak not smoke, it was billowing up onto the windscreen. Onto the trailer and home. I'll do a separate thread about the repair (once I work out what it is ), but the immediate problem was the bonnet wouldn't open because the front was pinched onto the front bar and would not release. Ultimately we unbolted the hinge from the bonnet, pulled it back a little and it released from the front OK. "There's your problem", the top radiator hose had popped off at the radiator.
