  • Replies 71
hey all
i've always wanted to get into drifting, nothing serious, just on the weekends at a track, but i have no idea how much it would cost. im curious as to how cheap you can build a drift car, im talking the bare minimum required to get it sideways.
you can slide a stocker, the more mods the easier it becomes up an till a point
make sure your lsd is working, if its not replace it with a mech or weld it up.
few engine mods, exhaust, boost ,fmic
suspension mods, anything you like really just depends how much you want to spend.
easier to learn to drift in a stocker than a 400hp crazy drift car
Edited by [Michael]
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3960580
Iam wanting to do this too.
But money is the base of drift, unless your sponsered LOL!
I was thinking just buy a Stock Nissan Silvia S13 K's, upgrade the suspension, Wheels / tyres, strut brace and brakes and start drifting, get use to the car and learn the drifting techniques then start upgrading the engine and push the limit a bit further.
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3960843
Hey man, was talkin to you last night at the meet...sorry man forgot your name already haha...my bad. Might it be cheaper if u just bought a Silvia J's even and drop an SR into it? If it's only for drifting...?
Justin
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3961180
What's the best sort of tyres for drifting? I have found that small truck tyres seem to be the go for burnouts and i'm sure alot of rubber is used drifting. The small truck tyres are good because they have lots of rubber to burn and are cheap. is this the sort of thing people use or what?
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3961219
i was considering getting a track drift car with a mate. share the cost. was looking at importing an already modded drift/track car just for that use so no compliance needed.
Thats probley a better idea, as in everything is there. All you need to do is take it to the track.
Justin
Hey man!
LOL! J's, I havent heard about them in years. There is a lot of Q's and usual K's but J's...
If they are very cheap and if you can source a SR20DET, then again probley another cheaper option.
If what you say about truck tyres is true, then thats a smaller hole in you wallet. LOL!
I go for that.
ALSO I was told that a CA18DET is a bit more stronger than a SR20DET...
Appently the SR20DET is a "board out" CA18DET so the walls in the block are thiner, hence easier to crack if pushed too hard.
CA18DET = thicker walls, hence stronger... But you gain a bit more torque with the 2lt as opposed to the 1.8lt...
True?
If so I guess save a bit more cash and get a CA18DET if cheaper, which I assume.
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3961333
Really? J's is still all i ever seem to see...and Q's...not so much K's...
ah well...yeah i actually heard that myself about the CA...more research is in order i think haha
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3961373
whatever it is, get a locked/shimmed diff at BARE minimum. if you dont have a diff that will spin 2 wheels every single time, you are just wasting your time and money.
coilovers is definately next, if your serious about drifting you want stiff, about 9/7 stiff for s13s (depends on the cars suspension setup and what motor ect).
a heavy duty clutch that will take the power your car has
decent steer tyres on somewhat wide and light rims is important too.
a harness, bucket seat and steering wheel like a nardi.
swaybars and adjustable arms (castor arms and rear camber arms are the first ones you want)
your car to not be a unreliable, worn out shitbox that will break down by the end of the session.
in the under 5k bracket, theres a few popular cars that have a decent aftermarket support and arent too hard to get parts for.
r31 - minispool diff centres on ebay for $80, s13 front end gear fits, s13 rear coilovers fit all round (rears need a little work) all skyline configuration motors bolt in, lots of aftermarket bits from other cars fit
KE70/Ae71 corolla, all sprinter bits fit, they make up in their lack pf power with their light weight. seriously cool cars when done up right.
ae86, can be found with basic drift parts for under 5k. if your gonna piss and moan about takumi tax, then get a ke70
NA s13 is probably the best chassis and the easiest to upgrade.
then theres other ones like older celicas, commodores, geminis ect but unless yoru willing to spend heaps of money or do alot of f**king around getting parts form other cars to fit, theyre not worth it. good reason popular cars are popular
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3961459
as for the cost side of it, you can pick up an alright condition manual r31 for under 2k no worries. as long as the motor and box are healthy and the cars not smashed, its ok. your replacing the clutch, tyres and suspension shit anyway.
example
car $1000
new hd clutch (not worth using second hand ones) $300
s13 coilovers second hand $500-$1000
s13 front end gear >$300
new decent steer tyres $400
mini spool diff centre $80
some decent steer wheels $300ish
harness $100
plus fresh fluids, belts, hoses, pads ect
start off using throwaway tyres from tyre shops, with a non turbo you wanna use 195s or 205s on a r31, 185s on a corolla ect, depends on your driving style.
add either trailer costs or rego costs, plus entry to the event, a helmet and fuel.
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3961466
An r31 is about the cheapest starting point with good scope for improvement. Even an NA with locked diff can turn the tyres reasonably well.
S13 is a better chassis but NA models are now as expensive as turbo models due to the p plate laws. If you are willing to spend a bit more up front (around 10k) you can get an srdet model with most of the good bits on it already.
truck tyres? f**k no. Make friends with all your local tyre shops and go through their rubbish pile regularly. You'll get some reasonably good tyres for the price of the fitting generally.
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3961473
Asked a friend tonight about the CA18DET and the SR20DET.
2 Completely different engines. So no, its not 'board out', nothing...
CA18DET is CA18DET
SR20DET is SR20DET
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3962098
R31, welded/spooled diff, s13 coilovers all round, strip the motherf*cker bare, remove all sound deadening, seats, spare parts, dash/heaterbox/aircon if your real serious. when you get comfortable with it, go buy a standard VLT conversion and front mount cooler + boost controller, easy 150rwkw. car with basic mods - ~2000-2500, extra for turbo kit - 2k will cover it easy
KE70/AE71, welded diff, heavy springs all round and shocks to suit, sigma lower control arms, steering/tied rod ends off a RT140 celica.... i think? and again, strip it bare. once your comfortable with that, 4age conversion is in order. basic car with mods - 1500ish, and about 2-3k for a conversion i rkn
the real important thing here that you neglected to mention was, does the car need to be kept registered or can you trailer it?
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3962315
You don't want to use truck tyres.
Believe it or not, but for drifting you actually want as much grip as you can get (once you get past the learner stage)
Grip = Speed and angle = bullshit fun.
Best idea is to find a good tyre shop and make friends. I have befriended a place close to me and the manager puts aside all the second hand 17's and I come in and get 12 rims fitted up at a time. They don't charge me for strip&fit only the tyres.
https://www.sau.com.au/forums/topic/224871-cheapest-drift/#findComment-3963127
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
