Stagea's rock......It confirms that Wagons are not just for Shagg'n but moving house....
I was able to easily put in 8 standard moving boxes and 4 book boxes....""Stuff 2 Men and a Truck" it's 1 man and his Stag.......
Jules
How you say it depends on where you come from!
If you want to stay true to the original pronunciation then it should be said SA TA GE A, because these are Japanese syllables. I have even seen it spelt this way in auction listings!!
Somewhere on you tube there is the original Japanese advert, you can hear it said on there. It certainly isn't STAY JA.... thats the Aussie slang kicking in! :D
The japanese translation from Hirigana is 'Sutejia' which is broken up to be pronounced 'su-te(tay)-ji-a' so i've always said it 'Stage-ee-ah'. and I've had my stagea longer than most people on the forum, so i trump most.
Mine is simply referred to as 'the pig' because one of my non-enthusiast mates didn't like the peakiness, bitey clutch or hard suspension... Personally, I love it: can't get enough of it :D
I want a stagea as my daily!
whoa, that's a win for the stag - you have an R34 skyline and you still want a stagea as your daily? that's kinda the same thing but with a lot less weight and considerably better handling isn't it?
I've had 40 cases of wine inside 12 sheets of 2440 x 1220 x 20mm particle board on the roof, all kinds of large furniture items inside...
After spending $2000 odd mine handles pretty good and, yes its quite heavy at 1620kg kerb weight but so is a Commodore SV6 @ 1733kg, a BMW 530i @ 1645, Alfa 159 wagon @ 1680 or an Audi RS6 @ 2025kg!
Having said that I would have a Skyline but
1. I'm too old
2. Too much persecution from the law enforcement (my Stagea is bog standard on the outside but working towards the 200AWKW on the inside).
Jules
Jules you dont happen to live on Warringah Rd, Forestville?
    • Lamb roast on Saturday will be different 🥲
    • They are under bucket shims. Tomei provides a test shim kit and then any measurement of shim required.
    • I always wondered how you were supposed to buy a set of 24 buckets and somehow magically have every single one of them yield exactly the desired clearance. I would have thought you'd need to assemble a cam with either 12 "sample" or "example" buckets of known top thickness (or a single such sample/example 12 times over!!) measure clearances at every valve, and then do the usual math to work out what the actual "shimness" of each bucket needed to be, before buying the required buckets to make up he thicknesses that you didn't have on hand.
    • I now seem to be limited in power due to my rev limit/hydraulic lifters in my built RB25. I'm looking into converting over to Tomei solid lifters. Question for anyone that has done the conversion. I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  I don't know where I got this idea, as so far I see no mention of this in any of the Tomei documentation. It just states I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
    • I couldn't agree more. I should have started from the get-go with a NEO or solid bucket conversion. I started looking into converting over to solid lifters yesterday. Now for some reason I was always under the impression that when using the Tomei solid lifter conversion, you would also require new valves (Longer or shorter stems, I can't remember which).  But I see no mention of this on any of the Tomei documentation. It just states that I need the Tomei solid buckets, solid lifter cams and upgraded springs. As my head is already built, all I would need is another set of 1000$ Kelford cams, 500$ buckets and about 4H hours of my time installing and I'm off to the races!?!? There's no way it's that simple, I must be missing something?
