we finally have a good 999 car.... eddie decided using other people's crap was too hard so he purchased quite a nice Emo 8, all prepped up :)
i drove said EMO 8 tonight, it's no GTR but nun the less not bad for an EMO
Ignition Module Needed:
Melinda's car (GTR #832) has new engine fitted and dynoed today by the great guys at GT Auto Garage, but it shit the ignition module half way through. finished the dyno with a lend from a customer car, but had to give it back. I have exhausted my contacts in Brisbane, and will try Just Jap tomorrow morning and see if Steve can bring one with him (if he hasn't already left?)
We are leaving for the drive down tomorrow night though, and would be good to know we have one before we set off..
Anyone with any ideas on where to source one
Cheers
Paul
0433 73 44 55
Edited by poolheaters
Cheers
Paul
0433 73 44 55
yeah the Just Jap guys have not left yet, give them a bell I'm sure they can bring another spare down.
Thanks for all for the replies guys, great response from the rally community!
We have a couple of leads to chase today in Brissy and and I'll ring the Just Jap guys today as well. Also a couple of modules waiting in Hobart if we need them..
Cheers
Paul
I'm arriving in Lonnie saturday. Will have the customary piss up at the Olde Tudor saturday arv/evening.... and this time, Dicky Johnson is joining us :)we finally have a good 999 car.... eddie decided using other people's crap was too hard so he purchased quite a nice Emo 8, all prepped up :)
I heard it comes complete with Bibles and Holy Water.....
A little off topic, especially considering the timing, but I'm going to Tassie with my car (on the boat) in the couple of months. I'm staying at Coles Bay for a couple of nights and won't be straying too far once there. I've got 3 hours to kill on arrival before my wife flies in, and then there is the journey to / from Coles Bay plus any worthwhile detours I could consider. I'm looking for some fun driving roads and thought if anyone would know it'd be the Targa crew.
If you've got any suggestions then perhaps PM so we can keep this thread clean(er).
Cheers.
That's easy Nick, take a run up the east coast to The Sideling, or any of the roads around Elephant and St Mary's Pass. Download a Targa Map and cross reference it, not hard to find great roads in Tas! :D
Edited by Marlin
Cheers
Paul
I have one I am not using for the next couple of weeks in Melb if you need it. Pretty sure it's at Racepace in Bayswater if you can drop past there and grab it.
Drop me a message if you need it i'll call ahead and make sure its there.
Yeah they're not exactly rare Paul, I'd assume you'd have one by now?
Yeah you wouldn't think so Woo but trying to get a good one locally yesterday was near impossible. Thanks to the JustJap boys and the Hobart connection at Moonah Auto Spares, there will be a couple waiting for us in Launceston.
It split the front turbo oil drain pipe on its last dyno run today, and had to get that from Sydney too, not a one to be found here..Hopefully that's the last of the issues?
Leaving at 5.00 in the morning, see you all in Tas
Well it's my module your getting from Moonah Auto Part's, Troy's taking it and your fuel drum's up to lonnie on friday
if you need anything else my car is apart on the hoist, so you can borrow most thing's, it's kinda like Noah's ARK
there's 2 of everything in my workshop at the moment, 2 engine's, 2 gearbox's, 2 diff's, there's shit everywhere...
Thanks heaps Burgz. hopefully we won't need it but good to have a spare. The one JustJap Steve is bringing down is straight off his car & proven good. He has changed to a R34 setup bacause he was sick of these failing all the time. Catch up with you for a beer down there..
Cheers
Paul
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
