Blaise, I'm not sure about you, but a 200kph speed limit? That's not racing in my world.
I'm told over 20 speeding penalties were handed out to competitors (2 min penalty!) - fair dinkum guys!
I'm hearing you Matt. People have tried to explain to me why it's a good thing but I always seem to lose interest and fail to hear them finish making their point. :). TW also has restricted speed zones and chicanes, repeats of all stages and all other sorts of ghey. (including about 200km competitive made up of multiple repeats, so lets call it 100. Main reasons why I don't bother and probably won't ever.
I like the open speed limit. Good place for those that dare to make up good time. It leaves you to just focus on the driving. I think most people found the restrict speed zones required for the damaged sections in TT 2010 a little troublesome/distracting. Also a mate who did TW on the weekend after having done TT earlier in the year found it quite dangerous having either a speed cut cut in or being distracted by checking your speed when you least want to be looking down. As you guys have said above, that's the whole point. Get from one end to the other as fast as you possibly dare. No one has a gun to your head making you do over 200. If that's all the minerals you got, as Woo says, just say so. :)
Re the chook cooker, have just turned the first spanner in earnest. Can't handle any more spectating. Have done the last two nights on it and the shell is just about stripped. Wil then start on the engineering of the rear suspension. (that's the bit I am sweating on) reality is th hope of maybe fronting up for THC 2013, but such a long way to go with the car and limited time.
Edited by Darkside
Had to be a spectator this year unfortunately... :geek: .it really didnt do it for me..
Finally sourced a doner shell with a 6 point cage from Sydney.
Should be on the truck next week.........now the fun really begins with transferrring the good bits from the bent car into the new doner car...
Can anyone recall any crash in Tarmac Rallying over 200kph? I started in 2004 and did at least 3 rallys a year, and I can't recall a crash over 200kph. So if it ain't broke, don't fix it!
It's up there with te 1kg of kitty litter we carry in the car - seriously - what is tat all about? Another knee jerk solution to a problem that doesn't exist.
I'm buggered if I'm walking back up the road "feeding the chickens" while Whitey flogs around the corner and cleans me up!
I can think of one... Greg 'i believe I can fly' Garwood. But that is 1 in 7+ years, which equates to 1 in 3000+ cars. But still speed, limits are no good.
And I've never seen anyone 'feeding the chickens'...not even the classics, which apparently have 80l sumps to drop oil over the entire length of a stage.
anyway Targa Adelaide is on this weekend, I'll be interested to see how Weeks old lambo goes against the Super Spagetti
^^^^^^^^^. Hahahhahaha. That puts it in perspective. Tarmac rally is for pussies!!!!! :)
While the world is still free enough to allow the Isle of Man TT and the rest of the road racing series to run, there is no place for Tarmac rally speedlimits.
Ps. Probably dead roo for protection :).
^^^^ wow! I'm sure there is a story in that..... Am guessing Quinny must have pulled 30 secs on sims for that to be possible?
From what i can see the Prolouge must be 2 laps of the same piece of road, and Quinny and Simsy came together on the overlap.
check the map and see what you recon
http://targa.com.au/tc/page_full.asp?asset_id=1638
    • Well, yes, every CU on the bus is available via the Consult port, but whether the scanner you are using is capable of talking to the TCU, the ABS/TCS modules, etc etc, is what is at question here. Many of them are only for engine codes. So, if you have one of those, you won't know if the ABS is having a bitch.
    • That's now. R chassis Skylines come from a time when the tolerance in the ADRs was a bit more....slack. My car, on 235/35-17, which is damn near the exact same size as the original 205/55-16, is pretty much bang on correct indicated speed across the whole legal range. That's demonstrated with constant speed run over 5km, and GPS speed. It's just the luck of the draw. My particular speedo head has to be the thing that is "calibrated" that way, because everything else (the diff ratio, the gearbox and the speedo drive**) are all same same as most other Skylines. **OK, so the speedo drive is a Navara unit to drive the R32's cable, not the electronic unit than an R33/4 would normally have with teh same gear on it. Otherwise, I applaud your OCD tendencies, and I would do the same if I needed to.
    • Not too sure, I believe the Nissan consult port does everything? Also just filled up the reservoir to full and the light is still on. The float seems to move up and down fine.
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph on 255/40 17, so again conservative Google says manufacturers need to set the speedo from 4 to 10% slower than actual road speed.....for safety.....and compliance  After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
