Tarmac Rallying Perpetual Thread
Marlin
Blaise, I'm not sure about you, but a 200kph speed limit? That's not racing in my world.
I'm told over 20 speeding penalties were handed out to competitors (2 min penalty!) - fair dinkum guys!
I'm hearing you Matt. People have tried to explain to me why it's a good thing but I always seem to lose interest and fail to hear them finish making their point. :). TW also has restricted speed zones and chicanes, repeats of all stages and all other sorts of ghey. (including about 200km competitive made up of multiple repeats, so lets call it 100. Main reasons why I don't bother and probably won't ever.
I like the open speed limit. Good place for those that dare to make up good time. It leaves you to just focus on the driving. I think most people found the restrict speed zones required for the damaged sections in TT 2010 a little troublesome/distracting. Also a mate who did TW on the weekend after having done TT earlier in the year found it quite dangerous having either a speed cut cut in or being distracted by checking your speed when you least want to be looking down. As you guys have said above, that's the whole point. Get from one end to the other as fast as you possibly dare. No one has a gun to your head making you do over 200. If that's all the minerals you got, as Woo says, just say so. :)
Re the chook cooker, have just turned the first spanner in earnest. Can't handle any more spectating. Have done the last two nights on it and the shell is just about stripped. Wil then start on the engineering of the rear suspension. (that's the bit I am sweating on) reality is th hope of maybe fronting up for THC 2013, but such a long way to go with the car and limited time.
Edited by Darkside
Had to be a spectator this year unfortunately... :geek: .it really didnt do it for me..
Finally sourced a doner shell with a 6 point cage from Sydney.
Should be on the truck next week.........now the fun really begins with transferrring the good bits from the bent car into the new doner car...
Can anyone recall any crash in Tarmac Rallying over 200kph? I started in 2004 and did at least 3 rallys a year, and I can't recall a crash over 200kph. So if it ain't broke, don't fix it!
It's up there with te 1kg of kitty litter we carry in the car - seriously - what is tat all about? Another knee jerk solution to a problem that doesn't exist.
I'm buggered if I'm walking back up the road "feeding the chickens" while Whitey flogs around the corner and cleans me up!
I can think of one... Greg 'i believe I can fly' Garwood. But that is 1 in 7+ years, which equates to 1 in 3000+ cars. But still speed, limits are no good.
And I've never seen anyone 'feeding the chickens'...not even the classics, which apparently have 80l sumps to drop oil over the entire length of a stage.
anyway Targa Adelaide is on this weekend, I'll be interested to see how Weeks old lambo goes against the Super Spagetti
^^^^^^^^^. Hahahhahaha. That puts it in perspective. Tarmac rally is for pussies!!!!! :)
While the world is still free enough to allow the Isle of Man TT and the rest of the road racing series to run, there is no place for Tarmac rally speedlimits.
Ps. Probably dead roo for protection :).
^^^^ wow! I'm sure there is a story in that..... Am guessing Quinny must have pulled 30 secs on sims for that to be possible?
From what i can see the Prolouge must be 2 laps of the same piece of road, and Quinny and Simsy came together on the overlap.
check the map and see what you recon
http://targa.com.au/tc/page_full.asp?asset_id=1638
    • Agreed with the rest. Also at least based on my own research, there are no readily available stock or close-to-stock RB20Neo maps that you could download and use as a base were you to buy a complete standalone ECU, and the regular 20DET maps don't really work well so you'd need to take it to a tuner if you have no experience. I installed an AEM V2 on my 20Neo+T and had lots of headaches until I got it to run and idle properly but I've yet to remap it fully. You have to start building up your timing and fuel maps entirely from the ground up; even the ones for a 25 didn't work at all.
    • Got some decent progress after work yesterday and also today. Got the ECU all wired and passenger side interior all back together. Kept the wiring up nice and high to avoid people standing on it. Got the surge tank relays rewired and tidied up the pump wiring and cut a hole to bring the cables through.  I found a spare USB cable I had lying around so I decided to cut it up and see if I could use it for my CAN 1 bus. Turned out one of the pins I needed was to the shield of the cable so i cut it up and desoldered it and resoldered to the correct pins.  Had the issue with the powersteering hose hitting the A/C compressor and fan shroud. I pulled the bracket off and modified it to remove the front mounting point which now clears it all. Will keep an eye on it to see if theres any signs of fouling once it's up and running.
    • That's some good input mate. Nice.
    • So today I went well outside my comfort zone (again) to replace my valve cover gasket.  I have had a big leak over the exhaust leading to a lot of smoke and smell every time I drove it. The leak was in the rear driver's corner.  The job wasn't hard as such, just a bit finicky and time consuming.  The old gasket was rock hard and broken right where the leak was.  The leaky corner had so much sitting oil in it.  The good news to my amateur eyes was no buildup or sludge under the cover. It all looked fairly nice in there.   I haven't started it yet. I ran out of light and body when putting the coils and injector loom back in. Probs only 30min left for the morning.  I was so nervous putting the cover back on, I must have lifted it 5 times to make sure the gasket was still seated properly. God it's going to be nice to be leak free and not make other traffic light queuers think my car is about to explode.
    • Gave the Mazda it's first wash, it will need some clay, a light compound, and polish polish to remove a few swirl marks, but that will be a job for when I have a full day to get my DA polisher action on
