R3N, that looks fantastic. Well done mate. I love the KD C Burnout lip and sides, especially in carbon, *drool*.
The R35 wheels are excellent, probably my personal second choice behind a set of large work meisters.
Exhibit a:
Exhibit a:
Very nice set up.
Very nice set up.
Just to clarify, thats a car in america, not mine =D
I did a quick dodgy photoshop on the side skits.
And i'm pretty sure they are fake work meisters.. i forget what size they are, but work do not make them in that size.
I've heard you can order custom made to your liking with Work, because there's one guy here in Perth, whose is a friend of a friend, with R34 GTR that he ordered for in 20 inch Work Meisters in Silver.
yeh my mate got custom made 20" meisters for his white r34 gtr
  • 4 weeks later...
Picked up my V35 last week =)
Full leather retrim
BBS LM's 18" x 9" +20 Front 18" x 10" +20 Rear
Thinking about getting exhaust and intake... any suggestions?
Thanks =)
Nice and clean V35 with good sets of rims, Ben. What kind of aftermarket grill you got if you don't mind me asking? Thanks.
Edited by Victor.T
Hey Victor,
Thanks just had the car detailed, as for the grill came with the car straight from japan, the rims were also imported from japan,
on a side note, has anyone bought kit parts from 'body kit kingdom'?
Hey Victor,
Yeah, you can tell the difference...colour really show up and the body lines are sleek and reflective.
With grill and rims, you had scored some parts. Nice. I just asked about the grill because I don't know the differences between aftermarket grills and for future reference if I want to get one. Thanks Ben. Good luck with the kit and post up photos afterwards.
Hey Victor,
just thought I'd let you know, found out my grill is branded 'illusion' ,
Hey Victor,
Illusion? Looks very nice. Thanks for letting me know, Ben.
Edited by Victor.T
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
