I farrrrrking want those rims Chris. Do want these as my next set for sure!
You will need the rims, and glasses with a special filter (as used on the camera or photoshop) for everyone that looks at your car to get the full effect. Edited by vee35
some up to date pics
rear bumper had some deep scratches I couldn't buff out so got it resprayed, thought I'd share a pic of the rear end stripped
also got my front grill repainted, I painted it myself but years of rock chips left it looking like crap, much better now & finished off with a rubber lip from ebay
M45 shift knob, won't get scratched on the metal trim piece like the stock version
Well Hi guys, Since I haven't post my picture for a while.
Here is the update I have done and Oh Also Selling the car as well :P
The following mods I have fitted are:
Motordyne space 5/16” Iso thermal plenum spacer
CF Intake pipe with JWT pop charger
Berk Hi-Flow cats + Exoticspeed Y-pipe + APEXi WS2 exhaust
USA Made Custom Grounding Kit
Nissan OEM Brembo brakes upgrades
Whiteline Adjustable swaybar Front and Rear
SPC Adjustable rear camber
Tein H-tech spring
Volk Racing LE37 Top Secret Edition wheels 19x9.5 +22 front and 19x10.5 +22 rear
Pirelli Nero 19" 245/35and Hankook EVO V12 19" 275/35
Works Paddle Shift and MOMO Gear knob
Nismo Front bumper
If I can't sell the car I'm Considering to put more mods like the Nismo Cluster, Transgo Kit and ECU upgrade.
well selling it because I just bought a Audi Q5 for the newborn baby and kinda don't need 3 cars right now.
At this stage I'm putting it $29,999 ono.
Love the Audi's, do like the body of the A4 sedans and seen them done up beautifly. How many KM's are on the car? Considering the mods, that's not a ridiculous price as they go for 20k stock with reasonably low KM's. (70ish)
Mine only done below 58k atm. When I bought it was with 28k km from japan through presti motorport.
When getting my q5. Saw a very nice sport package a4I b7 in black with s line kit and rs4 wheels in black. It looks amazing.
Edited by pw350gt
If you can find someone who likes all the mods. That's the downside of mods, when it comes time to sell, it is unlikely you will find a buyer who likes exactly what you have done. You can spenk $3k on rims, but if the buyer doesn't like them, they won't pay more for the car than for one with stock rims.
Very true, i personally would rather buy a stock car as i have because i know that something hasn't fuc*ked around with anything and done a dodgy job installing something. Peace of mind.
Got some new wheels....
she's still sitting at monster truck high right now, suspension will be next:)
Getting mixed reactions and some strange stares lol.... people either like it, or hate it..
but I like it, so thats all that matters:)
Specs -
Front: 19x9.5 245/35/19 +12
Rear: 19x10.5 275/30/19 +12
- Holly
Specs -
- Holly
Need major low, you can stick a closed fist in that gap. Other than that i do have much respect for running bright pink wheels major respect
Infinity badges were on it when I purchased it, but I actually moved here from the USA just last year, so I would have done them anyway:)
You need some more pink somewhere to offset the wheels.e.g pink grill or pink side mirrors or even a pink overlay on the lights
    • Update 3: Hi all It's been a while. Quite a lot of things happened in the meantime, among other things the car is (almost) back together and ready to be started again. Things that I fixed or changed: Full turbo removal, fitting back the OEM turbo oil hardlines. Had to do quite a bit of research and parts shopping to get every last piece that I need and make it work with the GT2860 turbos, but it does work and is not hard to do. Proves that the previous owner(s) just did not want to. While I was there I set the preload for the wastegates to 0,9bar to hopefully make it easier for the tuner to hit the 370hp I need for the legal inspections that will follow later on. Boost can always go up if necessary. Fitted a AN10 line from the catch can to the intake hose to make the catchcan and hopefully the cam covers a slight vacuum to have less restrictive oil returns from the head and not have mud build up as harshly in the lines and catch can. Removed the entire front interior just shy of the dashboard itself to clean up some of the absolutely horrendous wiring, (hopefully) fix the bumpy tacho and put in LED bulbs while I was there. Also put in bulbs where there was none before, like the airbag one. I also used that chance to remove the LED rpm gauge on the steering column, which was also wired in absolute horror show fashion. Moved the 4in1 Prosport gauge from sitting in front of the OEM oil pressure gauge to the center console vents, I used a 3D printed vent piece to hold that gauge there. The HKB steering wheel boss was likely on incorrectly as I sometimes noticed the indicator reset being uneven for left vs. right. In the meantime also installed an airbag delete resistor, as one should. Installed Cube Speed premium short shifter. Feels pretty nice, hope it'll work great too when I actually get to drive. Also put on a fancy Dragon Ball shift knob, cause why not. My buddy was kind enough to weld the rust hole in the back, it was basically rusted through in the lowermost corner of the passenger side trunk area where the wheel arch, trunk panel and rear quarter all meet. Obviously there is still a lot of crustiness in various areas but as long as it's not rusted out I'll just treat and isolate the corrosion and pretend it's not there. Also had to put down a new ground wire for the rear subframe as the original one was BARELY there. Probably a bit controversial depending on who you ask about this... but I ended up just covering the crack in the side of the engine block, the one above the oil feed, with JB Weld. I used a generous amount and roughed up the whole area with a Dremel before, so I hope this will hold the coolant where it should be for the foreseeable future. Did a cam cover gasket job as the half moons were a bit leaky, and there too one could see the people who worked on this car before me were absolute tools. The same half moons were probably used like 3 times without even cleaning the old RTV off. Dremeled out the inside of the flange where the turbine housing mates onto the exhaust manifolds so the diameter matches, as the OEM exhaust manifolds are even narrower than the turbine housings as we all know. Even if this doesn't do much, I had them out anyways, so can't harm. Ideally one would port-match both the turbo and the manifold to the gasket size but I really didn't feel up to disassembling the turbine housings. Wrapped turbo outlet dumps in heat wrap band. Will do the frontpipe again as well as now the oil leak which promted me to tear apart half the engine in the first place is hopefully fixed. Fitted an ATI super damper to get rid of the worn old harmonic balancer. Surely one of the easiest and most worth to do mods. But torquing that ARP bolt to spec was a bitch without being able to lock the flywheel. Did some minor adjustments in the ECU tables to change some things I didn't like, like the launch control that was ALWAYS active. Treated rusty spots and surface corrosion on places I could get to and on many spots under the car, not pretty or ideal but good enough for now. Removed the N1 rear spats and the carbon surrounding for the tailpipe to put them back on with new adhesive as the old one was lifting in many spots, not pretty. Took out the passenger rear lamp housing... what do you know. Amateur work screwed me again here as they were glued in hard and removing it took a lot of force, so I broke one of the housing bolts off. And when removing the adhesive from the chassis the paint came right off too. Thankfully all the damaged area won't be visible later, but whoever did the very limited bodywork on this car needs to have their limbs chopped off piece by piece.   Quite a list if I do say so myself, but a lot of time was spent just discovering new shit that is wrong with the car and finding a solution or parts to fix it. My last problem that I now have the headache of dealing with is that the exhaust studs on the turbo outlets are M10x1.25 threaded, but the previous owner already put on regular M10 nuts so the threads are... weird. I only found this out the hard way. So now I will just try if I can in any way fit the front pipe regardless, if not I'll have to redo the studs with the turbos installed. Lesson learned for the future: Redo ALL studs you put your hands on, especially if they are old and the previous owners were inept maniacs. Thanks for reading if you did, will update when the engine runs again. Hope nothing breaks or leaks and I can do a test drive.
    • No those pads are DBA too  but they have colors too. I look at the and imo the green "street" are the best.
    • I’m not sure what happened I told them about sonic tunes free OTS tune and the next the I know .. I was booted..   To funny
    • Yea - I mean I've seen my fuel pump which is decades old and uh, while I'm not saying this with real knowledge... but I sure get the ick at using anything in the fuel system that produced the state of that pump. Many years ago I went through multiple pumps (and strainers) before I dropped the tank to clean it out with extreme violence. I'm talking the car would do maybe 50km before coming to a halt, which resulted in me cleaning out the filter with some brake cleaner and going on my way. None of my stuff ever looked like what came out of your fuel tank. I don't think I'd be happy with it unless every single component was replaced (or at least checked/cleaned/confirmed to be clean here).
    • I'm not going to recommend an EBC pad. I don't like them. Just about anything else would suit me better. I've been using Intima pads for a while now.
