thought i'd join in, just got it for a week now and loving it
not sure which mods to do first but considering
- powdercoated wheels
- autokits rear diffuser (maybe eventually i'll want a front lip and side skirts too for a sportier look)
- grounding kit?
- full exhaust
- air intake
- custom dyno tune
- rear sway bar
- coilovers
Edited by mkn23
  • Like 1
- grounding kit?
- full exhaust
- air intake
- custom dyno tune
- rear sway bar
- coilovers
Choose your exhaust carefully... Beware of the 'drone'.
half asleep parking in a shitty parking spot at work... scraped the pole. yay me haha
First quote is $1120 to fix ... seems pretty OTT. Probably because of munching the quarter panel as well as the front bar. Any recommended crash shops?
Without seeing the damage that sounds about the price to repair both the bar & the quarter panel. If your in Sydney- Ultra Motor Body repair at Homebush West - In my street . I doubt they will be cheaper but their work is always great.
Finally installed the rims that I brought from Japan as check-in luggage haha
My Rays Volk TE37 are lighter but the SSRs are not bad too!
Before & After
Before & After
post-133804-0-20585100-1426599938_thumb.jpg post-133804-0-04329100-1426599966_thumb.jpg
post-133804-0-49400400-1426599909_thumb.jpg post-133804-0-56529300-1426599632_thumb.jpg
SSR GTV03 Matte Black
post-133804-0-36256300-1426599606_thumb.jpg post-133804-0-13606800-1426599660_thumb.jpg
Front 8.5J 18 inch +22 Offset 11.00Kg
Rear 9.5J 18 inch +22 Offset 11.20Kg
post-133804-0-97146800-1426599720_thumb.jpg post-133804-0-67131200-1426599740_thumb.jpg
New rear tyres: Achilles 123S 265/35/18
Edited by allankt86
Before & After
Before & After
Best. Wheels. Period.
  • 1 month later...
After going without a Skyline for almost 5 years due to the death of my old R33 RB25/30 setup Ive finally made the move into a more livable daily setup.... So Here's my recent purchase, 2008 370GT Type S with 32,000kms
Pretty much stock aside from a Fujitsubo Legalis R Axel back exhaust (Didn't know you could only get that section without the whole cat back :unsure: but anyway...)
Have also re-styled my plates to the New NSW Import versions :yes:
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
