  • 1 month later...
  • 3 weeks later...
  • 3 months later...
  • 1 month later...
  • 3 weeks later...
On 10/3/2018 at 2:16 PM, Mclarenmercman said:
I do actually
Oh i didnt get a notification you replied.
Would you sell it? Im chasing that style for mine but nothing around brisbane ?
@Mclarenmercman
Edited by DashyyPC
  • 1 month later...
  • 1 month later...
  • 2 months later...
Little update to my v36's look compared to the pics above.
now i have the following!
- SP Front bar with washers (ill eventually get them working when i get the right hoses)
- clear mesh front grille
- Long tube CAI's
- Headlights customised again to add DRL strip which is also sequential indicating
-Work emotion D9rs with the following specs
19 x 10.5 + 30 Rear
19 x 9.5 + 22 Front.
The black one in the back incase people ask is my best mates.
Mostly the same mods except he has the stock base model bar with a lip and the wheels are as follows
aodhan DS02
19 x 9.5 + 22 all round.
56622469_620542061727626_6655917540235018240_n.jpg?_nc_cat=106&_nc_ht=scontent.fbne3-1.fna&oh=f0f4dc6fe46a87edb1a9ed8f1a1a9fda&oe=5D47EDC1
  • Like 3
  • 1 month later...
  • 9 months later...
