still yet to clean the inside of mine. I need to organise the rear of it still as that still is in work guise and the front of it still has the Computer in the front seat. I've had enough of cleaning for the night. I'm going back out int he morn and continue cleaning..
  • Replies 317
+1 on the sunglasses, just ended up having a few at home last night, farken glad I didn't end up going out I wouldn't be able to wake up today :(
OMG how PERFECT is the weather btw, awesomeeeeeee!
It's an absolutely beautiful day here on Bribie, sun shining, gentle breeze, storm bird calling out, etc. etc.
Edited by stubby131
Sif you'd go on the SCC...
yes i'm sad....i'm still in Mt Isa....no showing off the newly running R32 GTS-25t. :(
enjoy your day peeps, save some prizes for me.
Anyone on the southside meeting up anywhere close by Carindale?
May I politely suggest that the next cruise be organised for earlier in the year? Every year this is on it is stinking hot and crap weather to drive in let alone have your bake bake in to get back in it to drive home.
Just a suggestion - I know it is qld etc but there are plenty of sunny warm days in winter where it would be much more comfortable for people and cars alike.
###MUST REITERATE### Great job organising the cruise etc. Always great. just not as much fun with heat stroke
top day - warm but a great turn out of 31-35 series cars think there was 110 cars over all . the execs will have final numbers
congrats to CHOYDA (damo) for show and shine and winning the Garmin Nav.
the longest distance winner was from kingaroy and he won the radio/speaker package.
good to put names to a few more faces.
cya next year !
Was a fantastic day, beautiful weather. Kathryn and I had a absolute great time. Good work execs! Imagine tracking up, down and around those mountainy roads in the pouring rain... would have been interesting. Looking forward to see some pictures.
Also forgot to speak to you Anna, about membership. Guess I'll just do it the normal way.
Edited by hojak
    • I'm actually not sure - I think it was "Stealth Performance" (It really is near impossible to find a FEMALE 1/8BSPT to 1/8NPT male at ALL) but having the thing leveraged on a 90 degree angle on a small aluminium fitting is not too smart. Also in not too smart, I've drilled out the center of the broken fitting so there's maybe 0.00001mm of thread to bite into, so yeah. I may have to get it drilled/tapped/plugged entirely. Given I could conceivably tap a thread/adapter/pressure line in any point in the oil system I suppose it's feasible to run a line to the Nissan Sensor to keep the dash working. Do these exist in AN fittings and the like? Like an AN fitting that has a NPT (or other?) thread as well for putting a sensor in?
    • I would agree.  There will be an amount of boost you could run safely with an otherwise factory system, but it would be low enough to not be worth the cost.  And if you are reliving your 20s, you know a 'little bit' was never enough. Personally, if I didn't want to spend the money, then stick with NA bolt-ons, and maybe a tune.
    • Fuark, at least the motor survived. What brand was the fitting that snapped?
    • Wrong question. There's no point in spending the rather large sum of cash and effort to add turbo, without taking it to the "sensible" limit of the motor itself. If you have to upgrade injectors, etc, then so be it. That is a tiny fraction of what it will cost you to turbo it.
    • Measure voltage at the starter solenoid terminal when the key is at start and it has clicked. If it is really low, then the suspicion falls on the ignition switch (contacts or wiring thereof) as causing a voltage drop instead of sending enough volts to throw the solenoid all the way to engage the starter itself. If it is a decent voltage, then the suspicion is on the solenoid. Might have s horted coil, or might hva dirty contacts. Rip the starter off, dismantle, clean up contacts and inspect winding. It might not be possible to see if there is a short in the winding though. I have a spare starter here that I could measure the resistance of the coil, as a guide to about what it should be, if you need a comparison. <parts hoarder>No you cannot have it.</parts hoarder>
