  • Replies 317
9 days people!!!!!! Remember, we are leaving Aspley as close to 10am as we can. All the meets organised for down South need to be brought forward as I think you will want to be in the carpark at the Hypermarket at no later than 9.30am.
Please remember, no skids!! No opening of wastegates! And no shenanigans in the car park!!!
Hi again to all the Gold & Tweed Coasters that are going
I have edited the times again for the meets so we wont be late as suggested for the Aspley meet
Anyone going on the cruise coming from Tweed & Gold Coasts, there is a meeting point @ Maccas Nerang @ 7.15 am there we will be leaving around 7.45 am to meet up with others @ Loganholme Hyperdome way before 9 am and then on for the Aspley Hypermarket meet before 10am as all will be leaving just before or on 10 am. So anyone coming to the meet @ Nerang i suggest don"t be late.
Cheers ;)
any one wanna offer to be a decoy skidder if i get pulled over??
stuff that. I would hAVe only had my licence back for a couple of days! Hopefully ur lucky and they dont pull u over :P That would be pretty rude if they did. Its a charity cruise!!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
