Does anyone have a definite list of stations stocking E85?
I am working on a facebook group to get the word out on E85:
http://www.facebook.com/groups/edit.php?su...gid=32246238262
Edited by dano4127
i did a service on the car after the 2 weeks of running e85.
The fuel filter was blocked. When i mean blocked i mean you really had blow hard to get any air going through the friggin thing. Now i have been lazy and have not changed the filter in about a year as well so that might have had something to do with it.
Another thing i noticed is the line between the steel fuel line to the fuel filter had cracks all over it, kinda feels perished, it will need to be replaced in the next week or so.
I also got 450km's to a tank of Mobil Synergy 8000 (98) over the weekend, mixture between freeway driving (300km's) and around town.
So yeah the difference in a tank of fuel is about 130km's
fuel filter would be as every page i've read says change your fuel filter after a tankful of E85, it loosens all the shit in your tank. perished hose would probably have more to do with the gigawatts he's running under the bonnet :thumbsup:
did you check this stuff before? is t deff from the 85?
Nope. have not checked it in over a year :rofl: but i did read you need to check after you run e85. so i did.
Filter was soo blocked hey, ive never seen a filter so blocked before. EVER.
fuel filter would be as every page i've read says change your fuel filter after a tankful of E85, it loosens all the shit in your tank. perished hose would probably have more to do with the gigawatts he's running under the bonnet :)
Yeah 3.74 gigawatts :thumbsup:
nah... i think i have chucked it out tooo... just a standard ryco.. if i still have it i will find a way to hack it up :)
Guilt-Toy.
Did you cut the filter open to ensure it was blocked from gum and shit rather than the media collapsing?
Which brand filter was it? The usual ryco?
From another site , it's supposed to be the first servo on the left hand side past the Mechano set (intersection of Hume Hwy/Liverpool Rd and Woodville Rd) heading south . I believe it's locked and you need to go inside and see Sid who will check your car out for it .
I'd just like to be able to get it in my fuel containers so hopefully that won't be a problem .
I can understand servo owners being a bit concerned about letting people toss it in the tanks of cars not specifically designed to run it . In proper fuel containers it should be ok and relieve them of any legal dramas .
Cheers A .
Excellent thread, Guilt Toy. There is some very good info' in here.
It would appear, after reading your results, and info' on other sites, that the E85 'picture' is looking very good indeed.
I've elected to upgrade to 780cc injectors, which would appear to be more than capable of supporting mid 300rwkw based on your results.
The plan is to do a tune for 98, 110 Martini and E85. I'll be sure to post my results - aiming for sometime later this month (20th?).
hey mate
I think i played wow with your girlfriend a few times lol
Anyway i think once you play around with e85 you won't look back. its a great fuel to use because its too cheap :P post your results should be good.
hey mate
Anyway i think once you play around with e85 you won't look back. its a great fuel to use because its too cheap :banana: post your results should be good.
Hey mate,
Ah yes, good ol' whatshername hey? :)
I'm certainly hoping that's the case. Will do.
I see in Adelaide there is a shortage of E85 and most the servos were sold out!
Hopefully the situation is rectified prior to the 20th. I don't need much, half to a tank will do - for starters.
you will go through a half a tank in NO time on the dyno ;)
you will go through a half a tank in NO time on the dyno :D
Thanks for the heads-up. I guess it stands to reason that dyno tuning to suit the E85 is going to chew through a fair quantity.
I have been told that E85 totally cleans your fuel system, even cleans the gunk out of your fuel tank.
So the fuel filter is needed to be changed very regularly until the system is completely clean.
Pretty soon most of the carbon will be out of the engine and your oil will come out as clean as it went in.
So i think a new fuel filter every 500km is on the cards for a while.
    • Wife wanted basket things in the wardrobe in our temporary house. Thought about ripping our the wardrobe and fitting the entire IKEA set, but it's a temporary house and we want to move in a few years. So IKEA advertises this as a 50cm unit, however the actually basket and rails measure 46cm wide. Only issue was depth, IKEA stuff is quite deep, where as the builder special junk is super shallow at less than 40cm. Send it, chopped the rails, then offset the mounting holes, job done, happy wife, less shit scattered all over the bedroom. Did the same to the other side too. Also drove the Skyline shit box today, dropped off oil at Supercheap Auto. I didn't realise they only now take max 2x bottles per visit. I visited 2x Supercheap Autos.
    • I've seen similar actually in my situation. You never know what tables are attempted to be used when the car thinks it's -99C or +200C. The fail state is not usually that extreme but you know what I mean - it was in my case though! This is where being able to read all the sensors is useful cause you see this stuff really quickly.
    • The above is very important. However as long as you keep timing relatively low, it's plausible to make your own knock ears and plausible to learn to tune with a modern ECU that can do wideband O2 correction like a boost controller. I mean if you only have one viable road to even drive the car on, learning to tinker to this level may be worth doing given you can't do much else with the car...?
    • I find the fact that the rear plate has to be bent inwards at the rear not so bad: but the front is just awful: It's like come on. (these are my very old, now retired/turned in plates) TBH it is a lot of money to fix a minor issue, the fact I said "I'll never really spend the money on doing this" is why people ended up buying them as a gift for a 'car guy' who can be hard to shop for.. for car guy things.
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
