Any updates?
Was going to ask you the same thing.
My engine has to come out of the car this weekend, few things going on thats put this project on hold for a little while. Once the new ecu goes in il be back to running E85
The race gas vs E85 issue is the reason I'm keen to back-to-back test 110RON Martini vs E85. I'm aiming to do this prior to the Xmas holiday period.
Sunoco costs me $10/litre...how keen do you think i am.
Do you have enough injector for it, Paul?
my new runners from Hypertune have injector bosses on both top and bottom.
two sets of 1000cc injectors should cover it.
Edited by DiRTgarage
6 lengths of garden hose will do the job too and far cheaper :(
Seen a few highpowered cars running E85 on Friday night. Smells sweet exiting the exhaust :P
Im keen to get my car tuned on it now.
Any updates Anthony?
Whats your economy like now?
I am in the middle of changing ecu's.. so i am back on 98. last tank i got 460km's so worked it out to be 13 litres per hundred with 98.. with e85 my best was about 420km's to a tank.
The servo just past the Meccano set near Landsvale is refusing to sell E85 to the public . They claim (counter jockeys) that the government won't let them do so and that the company (Manildra Group ?) is only selling to people with certification .
Any idea whats going on ?
A .
There is another servo (albeit the same company) a few minutes away that sells E85 (corner of Ferndell St and Rawson Rd, South Granville). I might swing by over the weekend and see what is the G-O with the E85.
  • Like 1
Hi GT , there was an Asian lady and an Indian looking feller behind the counter and no power on earth was gonna get me the E85 pump keys .
I tried to explain to them that all I wanted was 4 liters but the answer was no no and no . They said that the last time I got my 4 liters was a mistake and it should not have been sold to me at all .
Just for the record I had ~ 40L of straight Shell 98 ULP and wanted to make it "E10" . I could not get through to them that 4 of 40 is 10% (yeah ok 4 of 44) and no I didn't want the usual low grade E10 mouthwash .
I left contact details but not confident I'll get a return call or message .
I think we need to find a way of accepting responsibility for what we buy otherwise the alconazis are going to make life difficult .
A .
    • Input shaft bearing. They all do it. There is always rollover noise in Nissan boxes - particularly the big box. Don't worry about it unless it gets really growly.
    • For once a good news  It needed to be adjusted by that one nut and it is ok  At least something was easy But thank you very much for help. But a small issue is now(gearbox) that when the car is stationary you can hear "clinking" from gearbox so some of the bearing is 100% not that happy... It goes away once you push clutch so it is 100% gearbox. Just if you know...what that bearing could be? It sounding like "spun bearing" but it is louder.
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
