Dumping twice as much cranking fuel in the engine, mine still has some issues at under 10 degrees. Obviously the lower the compression and further south you are, the worse off you will be. It really chuggs through the ethanol doing short school runs in winter...
Running the EMU previously I had no cranking enrichment table. I had to fit a stock injector into the plenum, with a 1L petrol reservoir and old stock fuel pump to get me started in the mornings. It worked well.
I'm starting to think water meth is a better idea than e85. No cold start issues, more k's to the tank, no jerries in the back on long trips. Perhaps even running 98, a secondary e85 tank and another set of injectors might work out better for me.
My car has no problems starting in the Icey cold winter monings on e85 must be atleast below 5•c outside cause there's ice on the roof and windscreens frozen starts first kick like I said before either you let it idle for a minute or if your in a hurry you just have to be smooth on the throttle for the first minute
It's all in the tune
Aslong as you have a good tuner and good spray pattern injectors should be fine cause in my brothers car when he had high flow std injectors it idled worse than my car on cold start and barely cauld accelerate for the first minute or 2 and that was on pump 98 the tuner told him the spray pattern was shit and it would have bad fuel economy and cold start so on e85 would be worse so definately need a good set of injectors Aswell
I've had my Nismo in tank flowing E85 for a good 4 years. Pulled it out for a check before Xmas and both the sock and pump looked brand new.
I have a magna fuel filter which I cleaned every 500km for 3000km then every oil change after that.
I guess I was lucky in having a clean tank to start with but I know a few people who have had dramas with pumps failing and filters blocking very quickly.
:whistling: :whistling:
They are, it's just that ethanol cleans ur tank and lines so most of the time ur fuel pump filter sock gets full of crud
I'm gona keep and eye on mine for the first month or so of using ethanol
I was one of the unlucky ones with a dirty tank, i blame it mainly on the idiots that removed my fuel pump ages ago and left the tank open for a few weeks :domokun: Since then nobody touches my car but me or JEM.....
I had a billet filter but it wasnt fine enough so the injectors copped it, after that we went back to Ryco inline with it and kept blocking those filters.... We re-did the whole system and cleaned the tank and its perfect now!
E70 in general is amazing BUT i had a lot of bad luck in a row which made it look pretty bad!
Sorry to crash thread but i'm trying to find some quick answers without starting a new topic. I have an R33 GTS-T with a GCG Highflow turbo (XTRGTST). What power range could I excpect to get out of it?
http://www.gcg.com.a...mart&Itemid=101
There are other ways to scratch a little more out of each setup, but it gets expensive for small gains. Larger exhaust will help, as will larger cooler piping/intercooler, at the expense of response. Porting the head and cams will gain some more power also, with the same response losses. If you want more power than that, it is usually suggested to jump a turbo size or two as it's cheaper, but everyone has a different setup, funds and goals.
The hassle is the stock rear housing, depending which one you have it will restrict the amount of airflow you can get out the back, thus limiting your power.
    • KW only offers a set for the R32 GTR. Popular options are D2 racing, Ksport or Öhlins. I have a D2 Racing coilover set, though I don't know for sure which one.
    • Well, the good news is you have more than one very good option for new coilovers in and around your country. Worth the drive over to KW to talk about GTR stuff.
    • Fair enough, I am in no way a tire expert so I'm not familiar with all the terms and conditions. I'll definitely note down the AD09 to potentially try in the future. Rain is not too big of a concern for now as I will probably only drive in the rain when I have to. And considering I still lack experience driving the GTR I'd more than likely take it easy too. I have coilovers in the car but as I barely got to drive so far I never bothered to even check if they are adjustable haha. The suspension is almost entirely old and worn as well so I suppose when I eventually fix that in the future that would make a huge difference.
    • There's not a great deal to report here .... except ...... FOR .... LSD!!!  I bought a Quaife LSD from the UK and shipped it here .... Wish I'd just bought locally cause the shipping and duty was $700! But there were so many diffs used in the E90s I just wanted to be absolutely certain I was getting the right one so I spoke with a supplier in the UK who builds race cars and they have heaps of experience with the E90s.  I pulled the diff out which was seriously awesome - I've never done anything like that before, I must have watched 1000 videos on YT about it as well as consulting the Bentley manual. It was super easy in the end. The diff was delivered to the awesome folks at Hornsby Diffs and will be back in a few weeks. I also replaced the diff bushings with some Nolathane ones.  Really looking forward to getting it back and getting back to the track or even the skidpan.
    • yeah... the 13kg/mm springs weren't always in there, I had 10kg/mm but doing a few SMSP commanded heavier front springs. It's so good now going into T1 and T2, just need more seat time and real tyres.
