Check this out!
This guy has some great ability and car control. Wait until you see him get around the single cone. I had to watch the whole thing twice........ ok, maybe I watched it more than that ;)
Ken Block's Gymkhana practice
https://www.sau.com.au/forums/topic/244600-ken-blocks-gymkhana-practice/
PFfff I could do that...that stuff is childs play
EDIT:....Oh wait...I actually watched the video....HOLY..! Man I wish I had an access to a course like that, Should invite that guy to the DECA
Bet the Segway guy's eyes were closed and his pants were brown
did he smash the back end?
almost... it looks like he hits what is old flimsy wooden boards which break up too easily to cause damage, however if they were concrete blocks there or something he'd have screwed the car up :P
