Folks, I've just rang Regency and spoke to an inspector regarding Window Tint and whats legal:
No tint on the front windscreen (except up the very top... but don't bother if it hasn't come from factory).
75% light transmission on the driver and front passenger side windows and the rear windscreen
35% light transmission on the windows behind the driver and front passenger (those little triangle ones)
Cheers
WHAT! Bah, thats ridiculous... I was thinking I'd remove the front driver/passenger myself but now that I'd need to get the rear remove too I'll just get the tinter place to do it - too much of a headf**k to do the rear.
thats it, you can be defected for anything as proven by member VU (non standard air filter - WHAT THE f**k????? meant to reuse a 10yr old filter hey?)
dont stress too much peeps, Karma will come 'round.... she always does.
there is always something you can get done for but that was his main concern. i would rather sell my car rather than go through regency
yeh im the same atm...
i want a datton 1600 :P fj20
every stock 2yr old Commodore I see sags at the rear from saggy springs, no way you could fit a finger under 50% of those on the road.
when this cowboy pulls you over, make him do shit from the book !!! no guesses, demand proper measurments, facts etc. if he guesses make a fricken complaint !!
dont accept it, take the matter all the way to a magistrate and have your say; if you feel strongly enough about the matter. its your right.
enough complaints about wayward cowboys and rest assured their career advancement in the force wouldbnt be looking very rosy
MAN... I just spent the last 20 minutes removing the driver/passenger door tint + the rear windscreen. I was booked into Auto Perfection tomorrow morning to get that done for $110 but just thought I'd give it a try myself to get the door window tints off to try get the price down... and god damn it came off with such ease that I did the rear windscreen too! If a first timer like me did that within 20 minutes with just a hot air gun, a knife and not a single mess... wtf they doing charging $110! :P guess I got to call them tomorrow to cancel it...
just make sure the dimister lines on the back window still work Vu, just incase u have accidently put a cut in one of the lines
Demisters should be fine. I only needed to pick at the corner to get the tint up enough for me to pick at with my finger and peel off the rest of the way so didnt need the blade to go anywhere near the lines. But yea, I cant believe it was so easy and I was going to pay $110 to have it removed!
    • Nah - but you won't find anything on dismantling the seats in any such thing anyway.
    • Could be. Could also be that they sit around broken more. To be fair, you almost never see one driving around. I see more R chassis GTRs than the Renault ones.
    • Yeah. Nah. This is why I said My bold for my double emphasis. We're not talking about cars tuned to the edge of det here. We're talking about normal cars. Flame propagation speed and the amount of energy required to ignite the fuel are not significant factors when running at 1500-4000 rpm, and medium to light loads, like nearly every car on the road (except twin cab utes which are driven at 6k and 100% load all the time). There is no shortage of ignition energy available in any petrol engine. If there was, we'd all be in deep shit. The calorific value, on a volume basis, is significantly different, between 98 and 91, and that turns up immediately in consumption numbers. You can see the signal easily if you control for the other variables well enough, and/or collect enough stats. As to not seeing any benefit - we had a couple of EF and EL Falcons in the company fleet back in the late 90s and early 2000s. The EEC IV ECU in those things was particularly good at adding in timing as soon as knock headroom improved, which typically came from putting in some 95 or 98. The responsiveness and power improved noticeably, and the fuel consumption dropped considerably, just from going to 95. Less delta from there to 98 - almost not noticeable, compared to the big differences seen between 91 and 95. Way back in the day, when supermarkets first started selling fuel from their own stations, I did thousands of km in FNQ in a small Toyota. I can't remember if it was a Starlet or an early Yaris. Anyway - the supermarket servos were bringing in cheap fuel from Indonesia, and the other servos were still using locally refined gear. The fuel consumption was typically at least 5%, often as much as 8% worse on the Indo shit, presumably because they had a lot more oxygenated component in the brew, and were probably barely meeting the octane spec. Around the same time or maybe a bit later (like 25 years ago), I could tell the difference between Shell 98 and BP 98, and typically preferred to only use Shell then because the Skyline ran so much better on it. Years later I found the realtionship between them had swapped, as a consequence of yet more refinery closures. So I've only used BP 98 since. Although, I must say that I could not fault the odd tank of United 98 that I've run. It's probably the same stuff. It is also very important to remember that these findings are often dependent on region. With most of the refineries in Oz now dead, there's less variability in local stuff, and he majority of our fuels are not even refined here any more anyway. It probably depends more on which SE Asian refinery is currently cheapest to operate.
    • You don't have an R34 service manual for the body do you? Have found plenty for the engine and drivetrain but nothing else
    • If they can dyno them, get them dyno'd, make sure they're not leaking, and if they look okay on the dyno and are performing relatively well, put them in the car.   If they're leaking oil etc, and you feel so inclined, open them up yourself and see what you can do to fix it. The main thing you're trying to do is replace the parts that perish, like seals. You're not attempting to change the valving. You might even be able to find somewhere that has the Tein parts/rebuild kit if you dig hard.
