It's not covered in stickers :)
No GTR spoiler.
When i get it i'll post up some pics of the engine bay, it's unusual looking but very tidy and very stock looking.
Car hasn't got chrome rims, ain't dumped to the ground either.
IMO it looks sporty. Not really RACE like.
If i get defected then it's err...back to stock i guess :)
Aleks
the engine bay mate if u know a skyline engine bay there is about 4 things u can notice a mile away.
- oil cooler
-front facing intake plenum
-aftermarket headers
- pod filter
not knocking it at all just making sure u know that (most) cops know them things if they have seen and skyline engine bay.
get a daily :)
- oil cooler
- pod filter
get a daily :)
This is going to be the daily.
I got little experience with the RB25, but out of 6 cars I went and saw this one's engine bay looked completely different. If I do buy it I will take pics.
Front facing intake plenum? what is that? :S
And i know pod filters are obvious :)
Aleks
Okay guys. I just read through 18 pages of this.
Is it really as bad as it seems? I'm a P plater currently and will be driving a 33 soon...
Engine Mods
*TO3-4 turbo
*G-ready plenum
*Injectors
*Headers
*GTR intercooler
*GTR fuel pump
*Oil cooler
*Double plated clutch
*Up graded brakes
*3 1/2 inch exhaust system
Cheers,
Aleks
r31 gts-r manifold...?
and yeah, the only car that is sleepier than that is mitchs [ RB26 ]...
Edited by scandyflick
Aleks
if you noticed on some other rb25's they have the cross over pipe that goes across the motor! that's the plenum and cross over pipe! and i've never seen a manifold like that on rb25's before! anyone know what it is? or if it is a r31 manifold?
this is what normally a rb25 stock engine would look like
Edited by nos man
I attached a photo.
G-ready plenum ? that's what it says on the add.
Also further questions,
Where can I get an emissions test done and what happens if i fail it but am not currently defected?
Cheers,
Aleks
I attached a photo.
Cheers,
Aleks
emissions can be done in a few places. i got mine done at sinergy motor sport buy why do you need it done???
and clean up the engine bay to keeps the cops happy. the cleaner your car is the less chance of having them ream you.
Don't you need to pass an emissions test to engineer mods such as injectors/turbo?
Aleks
im fairly surely exhaust mani is GTS-R from an RB20DET-R.
hi, just spent the last couple of hours searching around how to bring an interstate car into SA. Register the vehicle in your name interstate, then here you just transfer it over or take it Sturt for a VIN before the interstate rego runs out.
Now to my question which i couldn't find.........
What would happen if you left the interstate rego plate on full-time and they pulled you over and try to defect your car ? would it get sent to regency or would you have to get inspected in the state that its registered in ?
Technically you live and your car is registered interstate, what is the situation about getting defected interstate ?
pretty sure you cant get defected on interstate plates as its out of their jurisdiction ?
wrong Mitch doesn't matter where the car is from or going it can still be defected
if an interstate car was defected here you would take it over regency and if it was defected in its home state whilst transporting it here you would just take it over regency also
    • So, version 4 intake is on its way I was looking at these a while ago but at around $200 or more it was a little pricey for something that might not work, but, I had it in my watch list, but, I got a message saying it was on special, and I had a code thingie to use, it eventually came in at $120 delivered, so BAM, BUY NOW.....LOL I'll need to have a look when it arrives but I feel it will "look" better than what I currently have, as it comes with a PCV fitting, so I will be able to get rid of the alloy pipe that goes to the throttle body with the PCV fitting  Well, that's what the voices in my head are telling me  Oh, and this happened today Yeap, it was a Trojan, and it was cheap, so I headed back to the hardware store and actually spent a little bit more on a heavy duty,  one that was actually recommended by a plumber mate, a Cyclone one with a fibreglass handle that is actually rated for clay The broken shovel will eventually be "modified" into a short handle shovel
    • When you pulled it off, there is no signs of blown head gasket? Is it possible you have some other issues going on? Possible cracked blocked? Or do you think it's straight up lifting the head? Did you check what the head was torqued to before pulling it down (To see if possibly they're stretching, or starting to break threads out etc)?
    • Seems like a decent result for a modded JZX110. They are bulky in comparison to the 100 and 90 models (which I'd prefer myself) but they are getting very few and far between here in JP these days. Thanks for the detailed review and the import process into the UK. I also have a car which I'm hoping to export from Japan at some stage so it's good to know if someone from the UK was interested in it. By the way the corrosion underneath is par for the course for cars which were located in/near the mountains or along the Japan sea coastline. They get huge amounts of snow every winter and the sodium chloride is used on the roads. Many cars have some kind of rubber like treatment underneath but they tend to limit it to the wheel arches underbody and fuel tank. Suspension arms and sub-frames will have similar corrosion to your JZX110 which is a common sight. See it all the time and car dealers here generally don't even mention it unless asked.
    • If the sound goes away when you clutch in, the 1.5/2 way diffs are just shit, and you are a normal person. The diff is likely "fine" but driving at anything under 30kmh is a violent horrible experience. It would be exaggerated with solid diff bushings and subframe bushings if you have those.
